page not loading...
as bkman2020 said all devices should use this url.
cant say what else could be wrong, i'm guessing you are using the emulator? from the posts iv'e read it can be a bit tricky. I have not tried the emulator after login was implemented, so I dont know. what error do you get?
When I use
portal.iptvrocket.tv/stalker_portal/c/
it opens id pw pop up but error after I put numbers.
but I can't reset mac address because papiao is down.
From the start of service we where given those urls from the start as of those other portals given i have no idea where they came from as it looks to me is a sample url? I been using those urls from day one i had posted on my new thread here: http://iptvtalk.net/showthread.php?14106-Url-portals-that-work&p=111868#post111868
i'll try again yeah you are correct 11.iptvrocket.tv normally redirects the client to portal.iptvrocket.tv/stalker_portal/c/ but 11.iptvrocket.tv is DOWN atm so it wont redirect anything to the real portal at the moment. it is really as simple as that and why we suddenly see all these ppl with errors.
pvr stalker beyond v0.8.4 (kodi 15.2) can not redirect so here you HAVE to use the full url.
sample urls? what? the portals url's the providers give out are short hostnames for convenience, what I posted its simply the full url for rocket portal.
I can give you the rest to, this is widely posted and known around the forum?!
11.iptvprivateserver.tv takes you to portal.iptvprivateserver.tv/stalker_portal/c/
11.iptvrocket.tv takes you to portal.iptvrocket.tv/stalker_portal/c/ but not at the moment.
66.iptv66.tv takes you to mw1.iptv66.tv/stalker_portal/c/
and when 11.iptvrocket.tv is down it cant take you to the portal. very very simple.
did you ever tried to enter one of the short urls into your browser or reboot your box? I guess not. again you should try it takes 2 secs, start with rocket and see if you get a response or redirect. then try one of the other and see where it takes you.. the stalker client in mag or avov or the emulator behaves exactly the same.
@hotwarmguy (why do I feel funny writing your nick lol) thanks.. so you got it working with the full url to the portal after bkman2020 repeatedly told you to switch back in this and the other thread... strange eh? strange with the other successes too.
anyway i'm done talking to doors and helping out. i'll just say the as the others: wait it out guys..
@tuxen Thanks for your help. I don't how I started this nick...
you can keep it. or switch back when 11.iptvrocket.tv comes up. it wont matter, well maybe if it happens again heh.
EDIT: in theory you should connect to 11.iptvrocket.tv if you are able to that way they can move the real server url around if they ever need to.
Running Stalker 0.8.4 on a Minix Box with Kodi 15.2
Everything working great till this morning….now it says "Unable to load Channels"
Did the usual troubleshooting but same result….tried many times.
Im with the iks66 service and the url that is input into my stalker config is http://66.iptv66.tv
Haven't changed any settings since usually it is a issue at the server end.
Should I just sit tight or try something else.
Thanks bros.
Edit: I just clicked on the above url using my laptop and it says "Your STB is blocked. Contact your provider."
Everythings been running smooth till now and I haven't changed a thing…confused.
Hi troops,
even with the redirect in kodi 15.2 using stalker client I get unable to load channels. Below is a cut out of the log file. Anyone seen this error before? I tried resetting IPTV on the papiao site and also tried to amend the MAC but when I went back into the site my maw wasnt changing, it remained the same. So left the mac the same in kodi but still no joy
18:07:53 T:140210188830464 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 504
18:07:53 T:140210188830464 ERROR: CCurlFile::Open failed with code 504 for http://portal.iptvrocket.tv/stalker_portal/server/load.php
18:07:53 T:140210188830464 ERROR: AddOnLog: Stalker Client: StalkerCall: parsing failed
18:07:53 T:140210188830464 ERROR: AddOnLog: Stalker Client: DoHandshake: Handshake failed
18:07:53 T:140210188830464 ERROR: PVR - GetChannels - addon 'Stalker Middleware:http://portal.iptvrocket.tv/stalker_portal/c/' returned an error: server error
18:07:53 T:140210188830464 ERROR: PVR - GetChannels - cannot get channels from client '888': server error
18:07:53 T:140210188830464 ERROR: PVRChannelGroup - Load - failed to update channels
18:07:53 T:140210188830464 ERROR: PVRChannelGroupInternal - Load - failed to load channels
18:07:53 T:140210188830464 ERROR: PVR - Load - failed to load channels
18:07:53 T:140210188830464 ERROR: PVRManager - Process - failed to load PVR data, retrying
18:07:58 T:140210525177600 NOTICE: Thread RSSReader start, auto delete: false
18:08:00 T:140209509349120 NOTICE: Thread BackgroundLoader start, auto delete: false
18:08:00 T:140210205615872 NOTICE: Thread JobWorker start, auto delete: true
Getting this when clicking submit to change mac on the papaio site
A PHP Error was encountered
Severity: Warning
Message: mysql_connect(): Connection refused
Filename: models/donation_model.php
Line Number: 1851
Sorry to hear you are in the same boat radmacks - give me a ping if you get it going again bud and I will do the same
