page not loading...
Why use that one portal?
try reboot your box or go to 11.iptvrocket.tv in a browser, the host is down for some reason that's why. I wrote that.
using the full url takes you to the portal. again you can try this in your browser. you probably had your box on and watching for a while that's why you do not see the error.
also I have no idea if more of rocket service is down when you reach the portal.
asking questions is perfectly fine, he had he's box running. I did write why in the first post though. but its totally ok. we are all nice guys here.
and 11.iptvrocket.tv probably will be back at some point, I am just trying to help in the meantime which no one knows how long can be.
btw. leaving the full portal url does not matter so you do not have to switch back later. no harm is done.
My mag250 was having the "loading page" error and I followed Tuxen's info (post #17) about changing the portal to the full address and rebooted the mag and it now works.
Just letting everyone know.
All iptv devices should use tuxens instructions as that is the default url.
indeed they should, the shortened redirecting portal url that are in all the howto threads for stb boxes around here and users put in from the start are down, maybe its permanet, I dunno. mag and avov boxes can redirect so can pvr stalker 0.8.4, using the full url is certain to get you to the portal and you should really use that yes.
after I change portal to portal.iptvrocket.tv/stalker_portal/c/
mine getting error message.
I can't reset iptv papiao is down
Maybe it is not for android boxes?
as bkman2020 said all devices should use this url.
cant say what else could be wrong, i'm guessing you are using the emulator? from the posts iv'e read it can be a bit tricky. I have not tried the emulator after login was implemented, so I dont know. what error do you get?
what the heck why are you contradicting yourself now?
I just wrote and we tested here that 11.iptvrocket.tv is DOWN hence the change to the full url. did you not understand my reply?
please try and load 11.iptvrocket.tv in your browser, it wont work anymore.
now try load portal.iptvrocket.tv/stalker_portal/c/ in your browser and you get to the portal.
everybody has the shortened url in their boxes that's why we suddently see this thread and several others.
11.iptvrocket.tv usually redirect to portal.iptvrocket.tv/stalker_portal/c/ but since 11.iptvrocket.tv is down atm it wont redirect to anything.
anyway I gave the temporary? answer for now and several users with avov/mag boxes has tested that it works.
11.iptvrocket.tv will probably be up at some time again, but until then users can use the full url and they do not have to change back if/when 11.iptvrocket.tv comes back up.
