re IPTV Stalker
Ive got version 1.0.62
surely the above version is higher than 1.0.11 that you quoted
Uninstalled IPTV Stalker
installed master zip
confifed all
you then get "update available" this takes you to the above version 1.0.62 where you lose the extra configs as in the first post
.62 was a post by MetalKettle, which caused versions .7 and above to not be erased. You need to force refresh his repo, or get rid of newer SuperRepo repositories that may have that.
i too have this issue . disabled mk repo and uninstall superrepo. deleted plugin.video.stalker folder. deleted both versions of plugin .18 & .62. reinstall .18. same thing 'update available ' which in .62. seems i cant get rid 0f .62
3 works on the east coast. was having some difficultly with the epg only showing 8 channels when I changed the number. Finally changed it in settings file in iptv simple client user data to 3.000000 so, 2.000000 should work for central. The number must be exact I think.
Had to delete settings in iptv simple client and reset epg and pvr data also. Use notepad to open file and edit/ save as settings.xml drop down file type to all files.
Im trying to have a group of just movie channels and can see how to add group but can not figure out how to add channels to the group? edit figured it out in channel manager in live tv settings group management
Can someone please help me understand what time shift I should use if I am using the new "ALWAYS CODE EXTERNAL LINKS" as my XMLTV URL if I am in CENTRAL time zone? I have tried 0, -1, -2, 1 and 2, but the EPG guide is always off.
It should be set to 0 for all time zones. Make sure you reset the EPG from LiveTv before using. Which channel(s) do you see are off?
Come to think of it, it may be set for West Coast North America (Pacific). If you are off, go to the plus side if you are east.
OK I gotta ask whats the odds of getting logos added to this guide and channel list and if they are already there can I be pointed in the right direction i'm using the bit.do list and can't say it to many times great work by all who put in the hours and work. Edit: scratch this post I have it figured out google is my friend for sure.
@crazyxbmc. someone posted a pack of Logos here a while back.. You could tell iptv simple client to use those perhaps., may have to do a lot of file renaming though..
Im not going to bother with that.. Something coming soon that will make that redundant.
