Hello this is just wat I have been wanting I have followed the instuctions in post 1 over and over and for some reason my guide is blank the channels all work just no guide can surf everything but no guide im running kodi 14.2 on a android box and have the latest version of iptv stalker as of this morning I think the last version is .16 any ideals what I should try next epg says it loads but cant see no info
The EPG is not loading because of an issue with settings.xml in userdata/addon_data/pvr.iptvsimple/. Simply open the settings.xml file and edit line 7, replacing it with below. There is an extra space in that line. EPG will load fine after/
<setting id="epgUrl" value="http://tecbox.tv/repo/teciptvguide/stalker.xml" />
I think you get that error if you c/p the entire line in the first post. I'll fix it, just in case you use the Ctrl-c/Ctrl-v method instead of typing.
ok quick issue i cannot figure out:
i dont have the iptv simple client on my kodi any longer, i had it active, decativated it, and poof it disapeared,
so where can i get the iptv simple client dvr addon again? i cant find it anywhere
its no longer listed in my pvr add on's under the disabled addons list
Im not too sure but you can always do a clean install of Kodi
I just installed the latest IPTV Stalker version 1.0.18 and configured EPG per instructions. Seem to work fine.. Much better program info than Ivue. Thanks to all who contributed.
finally managed to get this set up with the latest 1.0.18 zip and the latest Epg guide looking great however quite a few channels stay on working etc for 30 sec plus but wont open,i know this is a work in progress but just interested to know if others are getting this happening
Carefully read the first line of the tutorial... you need to have 1.0.11 or greater.
re IPTV Stalker
Ive got version 1.0.62
surely the above version is higher than 1.0.11 that you quoted
Uninstalled IPTV Stalker
installed master zip
confifed all
you then get "update available" this takes you to the above version 1.0.62 where you lose the extra configs as in the first post
Thank you all for the work you all have put into this imho I think this is the best new add on to kodi to come out in a vary long time hope it last along time but that will depend on the server putting out the channels
