Epg guide not loading
OK, new problem. Using Mbox, MXII, Kodi 16.1, Bulit-in Stalker client. EPG guide stuck at 7:30 PM(EST) on Sept 11th. Tried clearing data, restarting guide, nothing changes.
Disable TV, then disable PVR Stalker client, then exit Kodi. Now, restart Kodi...upon entering, Clear Data in General and Guide, then enable PVR Stalker client, then enable TV.
Once guide does load, it always stops at 7:30 PM the next day
The guide only has a finite amount of data. If it poops out, reload it.
I am very confused regarding the guide issue for kodi. First of all, earlier in the day I installed the iptv emulator 8.08 and was able to get it working on my octa core android box but I didnt like how it performed. CNN and some other channels were perfect but others channels the video was like in slow motion and not smooth. I then decided to test the box in kodi using the built in stalker pvr client and got the channels working with better picture.
Where I am confused at is the remote url address for the guide..Is http://nfps.******** a short address for something? Are we supposed to sub the ** for some other characters?
That would be ninja for the ** characters. It sounds like you didn't turn off hardware acceleration in the emulator. The picture quality streams well on android octo core. There are 3 codecs in android KODI for HW acceleration and you should most likely turn those off for the best streaming quality.
You guys are awesome. Thanks ilan and expatter for the guide issue. In regards to the hardware acceleration in the emulation 8.08.03 I did turn of hardware acceleration and had to turn of media codec or CNN or some other channels would not pop in with only sound. Western channel was a culprit. slow...Thanks again all for the epg info.
Hello Friends:
For a few weeks now (roughly), my Stalker EPG data isn't loading (100% blank). In searching around, it appears that the URL http://nfps.e****** no longer works; and, in fact, visiting it via a web browser shows that that URL no longer exists.
Did I miss something? If not, what is the replacement method for getting Stalker EPG data?
Thank you! :)
