Epg guide not loading
Thank you Ilan, I follow your steps and my EPG channels information is loaded, really appreciated your help to people like me that really not have to much knowledge on this aspects.
CTC15
Work excellent!
Don't make it more difficult than is necessary. As the person in the prior post noted, it is working as I posted. So...
Condition 1 (You were using Stalker client NFPS):
If you had Stalker NFPS enabled, (1) Disable TV, (2) Disable Stalker NFPS, (3) Exit Kodi, (4) Do an IPTV Reset, (5) Start Kodi, (6) Enable PVR Stalker Client and configure it [instructions below], (7) In the EPG configuration portion, choose XMLTV only, Remote, and add the Remote URL that I posted earlier (and that is posted below), (8) In TV > General: Clear Data, (9) In TV > Guide: Clear Data, (10) In TV > General: Enable TV.
Condition 2 (You were using Kodi's built-in PVR Stalker client with the updater):
(1) Disable TV, (2) Disable the updater, (3) In the EPG configuration section, choose XMLTV only, Remote, and add the Remote URL that I posted earlier (and that is posted below), (4) Go to TV > General: Clear Data (5) Go to TV > Guide: Clear Data, (6) Go to TV > General: Enable TV.
Remote URL:
http://nfps.epg.ninja
The guide for configuring Kodi's built-in PVR Stalker client is available here:
http://iptvtalk.net/showthread.php?16461-PVR-Stalker-%28Kodi-Built-in%29-Set-up-tutorial
Hey Ilan, when you use the remote url to download the guide, is it a very large file?
Im trying to figure out why my data storage in Kodi has suddenly spiked to over 2gigs…used to be around 500MB before….I never download anything Im watching, only stream.
No, it shouldn't affect space allocation like that. In fact, it is the same file that the updater downloads. There is no difference in the file's size from before. It usually runs in the 12 - 17 MG range.
If you Clear Data, it should get rid of items associated with the guide. Make sure the updater is disabled or it will continue to download the file.
Frustrated: My stalker plus wont load. I have used this ninja repo about 20 times before but for the last week I cant get it to load. It starts downloading for ever then after 20 min it just disappears and an Installation fail error comes out. I am not doing anything different. I have checked about 12 videos and they all do the same as me buy in my case it does not work. Was there a change in the repo????
I read this other guy Hees is having the same problem with the stalker plus addon. What can it be
