Constant Buffering fix
What you do is to copy what settings that are in the appropriate file (for your ram) into your current advancedsettings.xml. If you didn't have an advancedsettings.xml, you would rename that file to that.
Thanks. What I did was copy the values from the OP file into my advancedsettings.xml file, replacing those values which were there originally with the new ones, as well as adding the other stuff. Is this correct?
