your isp may be interfering, try wiht a vpn
Is there any updated advancedsettings.xml for a CS918T DD3 2GB 16GBNand flash?. I see the file is up to 8gb??
Is there any updated advancedsettings.xml for a CS918T DD3 2GB 16GBNand flash?. I see the and 16G. I have Gfile is up to 8gb??
https://www.youtube.com/watch?v=ampUWiAwsEg
I have four of the CS918T with 2G and 16G I followed the following youtube video and it made a night and day difference on all my boxes, computer and tablet. It is more than enough buffer. Remember, if a stream is slow , no amount of buffering will help you.
Code:https://www.youtube.com/watch?v=ampUWiAwsEg
alucard is right the cachemembuffer size does nothing to live video, it skips the cache and goes directly into post demuxing buffer which have a fixed buffer of 8 seconds. where it can help is if you stream fixed content like movies/ppv channels, but the default cache or 30-50 megs should be more than enough for the highest bluray bitrates or something is off. you can adjust the 8 secs post demuxing cache, but not with that setting.Do not blindly enter values you see on these videos without understanding on what they are doing, you can cause more issues then fix them. Values are based on your device and memory you have available. The settings in this video are for streaming and have nothing to do with live TV which are the PVR Advanced settings. Have you tried the files in the OP?
in kodi's filemanager, click add new source, click browse and choose external storage, click ok, give it a name like sdcard and click ok again.ok i pushed it to my fire stick but how do i move it i cant find it in file manager if a go to install from zip its under sdcard but i cant move it?
M |
Any fix for freezing and buffering.
S |
Am i doing something wrong constant freezing
K |
Buffering
A |
Buffering a lot
