almost done making a fully renamed and reskinned kodi apk for android next setep full install of the build
good catch dara.. gonna remove a couple apps from the build actually as they should be installed manually.. ie stalker/epgpsycon, you might want to update the OP to remind folks that the version of the Stalker Client NFPS loaded is for androids and to install the appropriate version from epg.ninja.
it should be platform independant as most of the plugins are.
you will ahve to reinstall stalker nfps on anything other than droid ARM
bongskie, I am using NFPS stalker 103 on the same android Minix device, you can download it from hear http://epg.ninja if you type ninja in the search bar on this site you will get all the info, I did Disable any other Stalker, as not to clash with NFPS stalker 103 ,
Was not necessary to delete.
R |
Clairvoyance build video choppy
T |
Clairvoyance/Epg Ninja
B |
What is clairvoyance auto settings
M |
Clairvoyance Skin Not Working?
