its different on every device.. you need to see what works best for you by trial and error... jsut change it and restart kodi.. the startup animation will play smoothly when you are at a good setting.. if not, you need a current box..
I downloaded the installer about 2 hours a go . I finally got it to run but after it, crashed
the hole system. Note I did this on a Fresh Install of kodi 15.2 On A Amazon Fire TV
Gary
I have loaded this build several times but never see any animation?
install pvr.stalker.nfps from settings>install from zip>clairvoyance... or from the clairvoyance installer under updates. or set up the build in pvr.stalker using the instruction in the epg section of the forumFirst and foremost, Psycon, you did your thing with this build!!! I'm still new to all of this, but have been trying to find a build I really like. I snatched an AFTV for my wife, and had a simple ass SilenceRom build on it, but now she's chewing me out because there's no guide or live tv that works. Today, I decided to finally mess around with it, and put the Clairvoyance Build on, and it's on point. I just need some help with getting the Live TV back. Can someone PLEASE give me a hand at getting a good guide back on along with the Live TV
R |
Clairvoyance build video choppy
T |
Clairvoyance/Epg Ninja
B |
What is clairvoyance auto settings
M |
Clairvoyance Skin Not Working?
