[UP OR DOWN] Channels Reporting
I have a 1080P machine and I watched a 4K stream with no problem or messages
The only way that is possible, is if you have a STB that accepts 4K media. It then transcodes it down to whatever your STB Display resolution is set to.
*(ie; You can have a 720 resolution TV, and still watch 1080 channels (but you are not seeing 1080!)).
I've also seen special events that are originally broadcast in 4K UHD, but get re-streamed at 1080 HD.
EL REY Network (253) Down Again (No Video, Audio Only)
Ch 253 EL REY Network has audio, but no video again. This pattern seems to repeat every 2 1/2 to 3 weeks or so, sometime self-correcting or being fixed on the other end a day or two later, but when it stays blank like it has been for 3+ days or more, it rarely comes back on its own.
What's been observed lately is there's a static multi-color test pattern graphic image on screen, stating loss of signal, which would explain the loss of both audio and video when the static graphic image is on screen, but mainly it's just a black screen with near-perfect audio playing in the background (appx. 99% of the time).
BuzzTV xpl3000 running Android 7.1.2, with latest BuzzTV2 app v2.0 (247), hard-wired, 100Mbps
