[UP OR DOWN] Channels Reporting
The reason I asked was because I remember in the old FTA days something such as this was once posted. I know that was quite a while back just wasn't sure if such information was available. Not a huge deal if not possible was just curious as I'm sure many would probably like to see something like that to maybe help determine the most stable servers.
you do get there are only 3 servers here and are pretty much identical right?
so if a channel don't work it just isn't working
reporting a channel down is one thing but a status page for 100's of channels is perpostuous
and NBS is right...what does this have to do with Buzz?
what does this have to do with buzz?
I'm running a buzz although if made available it could be posted in a different category if necessary. From my experience using same server on two different makes the two would have differences on performance so assume if posted in this category it would show the stability of servers for people using buzz.
there is not really a rule about public m3u playlists or even just one m3u channel with no private support being used or advertised.
We do not like to see them much thou, but not really against the rules (perhaps the live link thing if anything).... But we did not create a sub-forum for them either, and so with no place seen to post them, then that would cut down on them being posted.... that was my card I was playing anyway :)
I deleted that first m3u posted awhile ago because it was a broken link.
