[UP OR DOWN] Channels Reporting
Back to what the original poster said, I must agree but as soon as you see an improvement, you hold your breath and it goes back to freezing or channels down. As a reseller I have lost 2/3 of clients for non renewals. November and December crushed me. I don't know what the future holds with NFPS but all I can hope and ask for is a steady reliable service, if not then its only a matter off time before I throw in the towel as well.
Crazed, hats off to all you do to keep us informed. You have been helpful to me and many others, but today NFPS is having some serious freezing issues and if it continues NFPS DOES need to speak up and inform us or at least pass it down to the moderators.
My 2cents,
Trilly
I guess things can be different for different users, maybe location, I do not know.
But in fact and by chance, I been sitting on channel 300 for the last 10 minutes. There is no freezing at all experienced here.
Don't think it's me. I ran speed tests on fast.com and speediest.net. Both were consistent on my Spectrum internet at between 60 and 70mbps, so I think the problem is on your end. Perhaps we're on different servers and mine is overloaded?
The problem seems to be on the HD channels. I ran though a few and they seemed to be the only ones that froze a bit. I'd get audio then the video would catch up.
I'm in So Cal and you?
Asesinopr, easier said that done. I had read your post and believe me I tried very hard to help each and every client I lost for their 12 months. I offered support and was always available. But the bottom line is that it was their dollars spent and they just didn't want another 12 months of the type of service NFPS has.
Hey guys i also experiencing the buffering but only on the HD channels the SD are working fine on my side. I checked the connectivity speed on the HD & SD and both the Internet speed is between 500kbps & 3Mbps. This speed is OK for the SD channles. Usually i seen on the past for the HD speed between 1Mbps to 6.5Mbps. Looks like there are some throttling on the HD channels...maybe someone could verify this...
