[UP OR DOWN] Channels Reporting
they are being transmitted in a lower resolution than most of the other channels therefore show only on part of the screen, you can zoom in but becomes very blurry to watch, hopefully they can change the resolution soon and add the 3 missing league channels.
Many Indian/Pakistani Channels are Down:
[1105] - DOWN
[1114] - DOWN
[1117] - Rename to= "Sahara One"
[1131] - DOWN
[1133] - DOWN
[1135] - DOWN
[1147] - FREEZING
[1163] - Rename to= "SONY TV"
[1166] - DOWN
[1168] - Rename to= "Halla Bol"
[1170] - DOWN
[1172] - Down
[1173] - Down
[1178] - Down
[1179] - Down
[1180] - Down
[1184] - Down
[1185] - Down
[1190] - Rename to= "Star Jalsha"
[1192] - Down
[1193] - Down
[1195] - Down
[1196] - Down
[1197] - Down
[1199] - Freezing
[1203] - Freezing
[1208] - Down
[1211] - Down
[1216] - Down
[1219] - Rename to= "Samaa"
Some channels need to be moved around to better fit in their proper sections.
-the following 4 channels need to be moved out of the Pakistani channels and into the Indian channels possibly list them after Channel [1154]
[1170] Set MAX
[1199] B4U Plus
[1202] SET MAX
[1203] SAMAY
following 1 channel needs to be moved down-
[1182] Aaj News - Moved down to Pakistani Channels in the 1200's
- the following channels need to be swapped
[1107] with [1166]
[1115] & [1116] with [1184] & [1185]
[1128] & [1129] with [1163] & [1168]
[1135] with [1174]
[1220] with [1311]
After All this is done, we will have proper Groups of Indian/Sport/Punjabi/Pakistani.
Then:
Channels [1101] - [1190] should all be listed under INDIAN
Channels [1191] - [1311] Should all be listed under PAKISTANI
Channels [1139] - [1145] Should all be Added to SPORTS LIST as they are also Sports channels.
Thanks for all the hard work NFPS.
Hi Astf
Channel 82 TG4 is DOWN
Channel 129 Bravo is FROZEN
Chanel 421 YES NETWORK still DOWN for weeks
Channel 424 Fox Sports Southwest is DOWN
Channel 1143 Willow message from DISH saying receiver has been disconnected
Channel 7788 ABC 5 Puerto Rico NEEDS TO BE RENAMED as ABC 7 New York
Channel 8102 NBC New York INCORRECTLY ENCODED currently showing green screen
Channel 8273 Fox 35 Displayed in 4.3 very badly encoded Pixel rated extremely low resolution
Kodi 6 Mbps
.ts streams not working
Hey guys,
Every time I open a .ts stream it plays for two seconds then closes. This happens with every .ts steam. On kodi, and on vlc.
Here are some of the links I have tried
Can someone help me solve this issue?
