Unable to load channels
Mac Address Mix match
Hi guys I'm getting and MAC address mix match after setting up epg ninja add on on my kodi 16.0.
I've reset my MAC address and changed it a few times and configured my donation number password to match.
I've rebooted router and android device re enabled tv and made sure settings are all right but won't load channels.
I'm using new pvr stalker client epg ninja repo.
If you are getting a device_id mismatch, that means the server doesn't recognize the client trying to use the MAC.... which means that the PVR Stalker NFPS isn't sending the last known device_id... because you rebooted your router or modified something else in on your platform.
If you use a MAC that worked previously...DON'T CHANGE IT, just do an IPTV Reset after you verified your settings and shut down Kodi (or diabled TV).
