To many stalkers
I WOULD RATHER GET THE STALKER CLIENT NFPS 0.8.4 WORKING With the guide, if I go to configuration page and change the last 6 digits and leave the donation alone will
that work, and just leave the IPTV STALKER 1.0.18 alone.
did that through I had it but no luck, I spoke to soon. IPTV STALKER NPFS does not go to lunch but back to configure--but
if I go to tv settings channel mgr I get channels but they will click on Group mgr I get a lot of groups--search for channels
it says none of the connected PVR backends supports scanning for channels. I don't know?
djmcshain,
Here is what you need to do. First off, disable all IPTV Stalker addons including PVR SIMPLE CLIENT. Then go here and change MAC to something like this:
00:1A:78:xx:xx:xx --->make sure at least one of the x digits is different to what has been linked before.
Once new MAC has been linked go to your Stalker NFPS and configure using your donation, new MAC and make sure you change server to Rocket server. Once settings rte all set, enable this addon and turn on Live TV under settings. That should do the trick
Happy Day after Thanksgiving to everyone. Had some time so I went to settings reset everything out. Installed KODI 15.2, fusion tvaddons, metalkettle.co and then downloaded
pvr.stalker nfps android arm 20151101.zip. Did not download IPTV Stalker 1.0.18.
When I go to system info--pvr info pvr backend stalker/middeware channels 866. Stalker client & Stalker client nfps o.8.4 only pvr enabled after I configure stalker nfps it goes back to configure not lunch. Then when I go to the tvaddond bar with pictures,tv, video, music, programs and systems then I go to TV on channels I got them and they work but on Guide I get no Guide entries, how do I get that to work?
iks66 is an exception the donation numbers will not work for rocket/nfps.
follow the guide above
or personally I think this is updated and much easier to follow, the other guide contains some old info in the pics that can be confusing with the text.
http://iptvtalk.net/showthread.php?6833-How-to-set-up-pvr-stalker-with-NFPS-and-have-a-Full-EPG very few steps and you are up and running.
read them both and hopefully you will get an understanding of how it works.
the first link dara gave you in post no.2 is also very helpful distinguishing the clients, and get a general understanding.
