PVR Stalker Client NFPS for OPENELEC
nothing sticks out other than I enter the server with http://
it should work as you have it though.
your getting unable to load?
are you using the same serial number,ect that your working iptv stalker is using?
if not reset your mac(change it by 1 number/letter) on papiao/iks66 and don't try iptv stalker,change your mac in pvr stalker to match.
enable live tv(the first time u will get unable to load),disable/enable live tv again and it should load second time.
openelec_stalker PVR
I'm on openelec on a MXQ box. Running OpenELEC-Amlogic.arm-MXQ-6.0.0.2 rom, which is kodi 15.2 with older pvr 0.8.4 the only connection_timeout ----- 15 . I did go into the setting.xml file and tried the 120 but no go.
This only works for me for a little while with NO EPG. As soon as I turn on/off the box can't load channels. I got it up and running for a minute with special://userdata/addon_data/pvr.stalker/epg_xmltv.xml (no EPG) then I installed the repository.epg.ninja and enabled still NO EPG. Then connection fail.
I have donations for both (66IKS) & (NFPS) I also tried https://papiao.is/main/EPG/mac/00:1A:78:xx:xx:xx/donation/xxxxxxxxxxxx/fname/NFPSF1 for both (66IKS) & (NFPS) NO LUCK. The Clairvoyants pvr zips do not offer linx for my application.
I just don't understand why at first it works then it stops.
I also uninstalled system and reinstalled. Tried New mac - reset mac, Clear data tons of times. Used mucky duck clear cache and packages. Reboot ...reboot. Going crazy cause it did work but won't hold. I also tried
hxxp://11.iptvprivateserver.tv/ which will work like the other for a minute, NO EPG then box off box on FAIL !!!!
UPDATE
I finally got it to stick on/off channels load (whoo) BUT..........LOL no EPG.
The reason the channels didn't stick was because when I kept clearing data it also clears 120 in the settings .xml file. So I go back redo and it finally stuck. But where the hell is my EPG!!! No joy.
Used
portal.iptvprivateserver.tv/stalker_port*al/c/index.html
Do I need to install the repository.epg.ninja , to get the EPG? I'm almost afraid to mess with it. LOL
UPDATE
just set pvr stalker 0.8.4 or 0.8.3 epg guide preference to local file and then set the path(navgate) to stotage/.kodi/userdata.addon_data.pvr.stalker and select epg_xmtlv.xml
that will allow pvr stalker 0.8.x to use the file that epg updater downloads.
for kodi 15.2 u probably need to enable the "get offset-1 Hour" option in stalker epg updater,in you menu's its in add-ons/myadd-ons/services/stalker epg updater then select settings.
THANK YOU ------------- with KISSES xxxx
at first it didn't work so I went back and looked at my setting.xml file and found I had to again set 120 time out and clear the old url.
Whoo Hoo ....JOY JOY.
My joy went away now nothing works. All my repos say incompatible. I did a new install and I still can't get any addons to work???
No clue. Did I fry the box ? kodi loads but no addon will work. Help
shut down kodi.
goto userdata/database folder and delete any addons.db files.could be named expample addons19.db,addons.20.db.delete all that start with addons with .db extensions.
start kodi and it will rebuild you addon database,all fixed.
Thank You AGAIN !!! Hugs & Kisses oxoxo ...... Joy .. Joy .... Stalker PVR with EPG working , all addons back to working.
This thread is too long already, but the best place to ask questions about the different clients and devices are on those forums, not the service forums.
Sorry but the repository.epg.ninja .. was the problem because after I redid my setup and reinstalled repository.epg.ninja it happened again.
So I did (Blackbear199 _ FIX /shut down kodi.
start kodi and it will rebuild you addon database,all fixed.)
and all is good again.
