My review of the Dreamlink T2
I guess that the only thing left to try is a sd class 10 card or an SSD drive but I don't have either so I'm checking to buy an SSD drive but i'M tempted to try another box like Z7+ or T2 because of the high prices of SSD ...:confused:
Yes and just tried another USB stick of 4GB with the same result with every format like exfat/fat32/ntfs, I'll try to make a short video of what I mean to show exactly my playback problems. What is strange is that I played the .ts file on my pc and there is no "slow motion" except a small blur of color at the beginning for a couple of seconds of each video but after that playback on my computer(with WMP or VLC) is fine (with great picture quality). So what I found is that the recording itself is not the problem but the way playback is made by my T1 + ...
Just ordered a Z7+ today because I'm so frustrated with this but since Dreamlink is also the maker of that device I'm afraid to get the same problem, who knows ...
Again thank you guys for your support:)
Did you try a factory reset that may help no guarantee
But sometimes it does wonders
Yes just tried 2 factory resets and 1 software reset, still same problem I tried with the reset factory file but pressing channel button up at startup does nothing for me, I don't get the "system update" message pop up, it just goes to where I was the last time I started the T1 Plus...:(
