most channels not working and vod not working are we down??
Good afternoon I made a list of favorites of 140 channels, to the date most are not seen. But the worst thing is that nobody gives you an answer.
They send you to the forum and no one solves you, I think until the moments with respect to the channels lack of attention due to lack of IPTV66 to their subscribers is the biggest problem
Sorry JonBoy, that is not true. Other than the Canadian channels, most channels are working fine with an occasional freeze here and there. Some HD channels in the 9000's are freezing a little more often. All in all, big improvement. I would do an iptv reset and then post what your using thats getting the black screens.
Pod77 I've got 2 MAG 254's and neither one of them get any DISH channels I've had a year sub on both. I've tried everything in the forms to turn them on. I feel that I've been taken for a ride !!!
Where does it state you get dish channels? If you want dish channels you need to use IKS which is a totally different setup and system... I think you are thinking iptv does the same as IKS which is not the case.. Your MAG has nothing to do or will get "dish" channels 😉 the only " ride" you have been taken is you don't know or didn't research what is what.... Maybe do a bit of reading before you state you have been taken for a so called "ride""""
Where does it state you get dish channels? If you want dish channels you need to use IKS which is a totally different setup and system... I think you are thinking iptv does the same as IKS which is not the case.. Your MAG has nothing to do or will get "dish" channels �� the only " ride" you have been taken is you don't know or didn't research what is what.... Maybe do a bit of reading before you state you have been taken for a so called "ride""""
pod77 pretty well every channel is down at the moment..we both know it happens,and this iptv guide was setup in the dis*h format from the get-go.
