[MOD] EPG with Genre Color (10.3.4)
yep! NO NEED TO FREAK OUT :p
dara is right
there's still no EPG update available from the source
the last one was 3 days ago
I made a new update update for my build (v10.3.4-r3)
which has an error-notification when the same error happens
NOTE:
the error-detection script will work perfectly ONLY IF an EPG cache file doesn't exist in the PVR userdata directory
hence either you can delete the cache file manually -OR- you can disable the EPG cache option in the PVR settings
DOWNLOAD:
http://www.mediafire.com/download/3gnrtp9sqg8437u/plugin.video.stalker-10.3.4-r3_(EPG-Server).zip
Thank you very much for your promt answer. I'm testing iptv stalker plus 10.2.4 (rocket22) in 2 PCs and a tablet fairly good. When I try to test 10.3.4-r3 only I get is access denied. Go back to 10.2.4 and every thing is ok again. What do you think is my problem? Do I have to reset my Mac in order for this version to work? Thanks again.
I don't know what you mean for "rocket22?", but it is the server that I choose in iptv stalker plus 10.2.4. What is the prefix in iptv stalker plus 10.2.4 ? If it is 00:1A:78, how I can change 00:1A:79 to 00:1A:78 in order to get access to the server? If there
is any question regarding what I am trying to explain, please ask whatever you need to know. Thanks.
I was just quoting what you said: :D
both my v10.3.4-r3 and dara's v10.2.4-r2 use the special prefix ("00:1A:79" instead of "00:1A:78") for the Rocket-22 's MAC
the previous dara's v10.2.4 use the ordinary prefix "00:1A:78" for all papiao stalker portals (incl. the Rocket-22)
here is a backstory behind why the "00:1A:79" was being uised
http://iptvtalk.net/showthread.php?18157-ROcket-server-22
if your current settings works for your IPTV, DO NOT CHANGE anything !
you could use my new update (v10.3.4-r4) instead
now it has a new option to input a custom MAC prefix ("00:1A:78" -or- "00:1A:79")
DOWNLOAD:
http://www.mediafire.com/download/c0e4xw08he9hmdt/plugin.video.stalker-10.3.4-r4_(EPG-Server).zip
Hi,
I may not have understood correctly from your instructions, but can you please explain why I need to run IPTV Stalker Plus and the PVR Stalker Client both at the same time?? I thought it was only possible to have one application linked to your subscription at any one time??
I seem to be able to get the Stalker NFPS client working fine with my subscription but the regular PVR Stalker client that comes with Kodi keeps coming up with authentication issues.
*Ok I've now sorted the stalker client authentication issues by using the full link for the portal "http://portal3.iptvprivateserver.tv/stalker_portal/c/"
However I am still having guide issues. It stopped working after a few days and I tried clearing my TV and EPG Databases and restarted the TV service but I still get no updated guide. Can someone please explain how the Stalker Plus add on by Couch Potato is supposed to run and if that is meant to be run at the same time as the Stalker Client PVR addon ?? If so, then I must be doing something wrong because I am not even getting any updates on when the guide was last updated. It'd make sense if someone had the time to incorporate the last updated message and also the extra features tab into the stalker client PVR addon as running two seems a bit crazy.
P.s I am using or trying to use the latest RC4 release of the IP Stalker Plus addon as posted by Couch Potato.
Thanks,
Prophercy
Hi, I can't see any difference between provider data and ninja-1 data? I'm missing almost all of the brit channel data and the rest is not categorized as expected. I know it is reading it from the epg server correctly because I tried setting it to an hour offset just to be sure, cleared data and it was an hour offset. Categorized is nice but rally just a complete guide is better ☺
Hey CP... I'm getting a "No epg update available today. The last one was valid until august 30th 2016" error...
Can you please advise if there is a fix for this yet?
I'm also getting an error when trying to access the VOD area within your addon CP...
Stopped
23:49:17 T:18446744073124952368 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('genres',)
Traceback (most recent call last):
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.stalker/addon.py", line 775, in <module>
vodLevel();
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.stalker/addon.py", line 347, in vodLevel
genre = i["genres"].split(",")[0]
KeyError: ('genres',)
-->End of Python script error report<--
23:49:17 T:18446744073507146032 ERROR: static bool XFILE::CDirectory::GetDirectory(const CURL&, CFileItemList&, const XFILE::CDirectory::CHints&, bool) - Error getting plugin://plugin.video.stalker/?cat_id=10&genre_name=VoD&mode=vod&portal=%7b%22name%22%3a%20%22iptv66%22%2c%20%22parental%22%3a%20%22false%22%2c%20%22url%22%3a%20%22http%3a%2f%2fmw1.iptv66.tv%22%2c%20%22ppassword%22%3a%20%220000%22%2c%20%22vodpages%22%3a%20%2210%22%2c%20%22mac%22%3a%20%2200%3a1A%3a78%3a36%3a98%3a64%22%2c%20%22active%22%3a%20true%2c%20%22serial%22%3a%20%7b%22send_serial%22%3a%20true%2c%20%22custom%22%3a%20true%2c%20%22sn%22%3a%20%22(account data)%22%2c%20%22signature%22%3a%20%22(account data)%22%2c%20%22device_id2%22%3a%20%22(account data)%22%2c%20%22device_id%22%3a%20%22(account data)%22%7d%2c%20%22password%22%3a%20%22(donor Number)%22%2c%20%22login%22%3a%20%22(donor Number)%22%7d
23:49:17 T:18446744073507146032 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.stalker/?cat_id=10&genre_name=VoD&mode=vod&portal=%7b%22name%22%3a%20%22iptv66%22%2c%20%22parental%22%3a%20%22false%22%2c%20%22url%22%3a%20%22http%3a%2f%2fmw1.iptv66.tv%22%2c
(lots of datastrings involving the donation number, device IDS,etc at this point, just deleting the info out of log posted for security of the donation number)
failed
23:49:59 T:18446744073124952368 WARNING: CPythonInvoker(49): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
23:50:01 T:18446744073124952368 NOTICE: iSTREAM: Subscription Auto Update Service - Starting\Waking...
23:50:01 T:18446744073124952368 NOTICE: iSTREAM: Subscription Auto Update Service - Auto Update Disabled, Sleep for 30 mins
23:50:15 T:18446744073156102448 WARNING: SMBFile::OpenForWrite() called with overwriting enabled! -
