Mag254 Setup Guide
9. Outer Portal- Advanced Settings- Buffer Size-
It should be noted that a higher buffer may equal less freeze time, but it also increases channel change time.
I started with max buffer thinking it would help as it did on Kodi, but Mag254's channels would never load!
I'd start with a max buffer of 5 and tweak accordingly up or down. ;)
I did check my mac#
Mac Address Status
This MAC Address xx:xx:xx:xx:xx:xx is good and ready to join
Still stuck at the blue screen , I went to the internet browser in the device and it loaded up google and verified I do have internet.
Anyone with a clue ? PS I did reboot it 15-20 times with the power plug , and from the MAG254 menu as well. Verified URL , updated unit ..
First timer setting up my MAg254.
Step 4 says
"4. Select "Auto update software" and set auto update to enabled. Press the green F2 button to update now. Then exit. "
But all I can do is select "Auto (DHCP)"
Where can I find and select the auto update option? thks
are there different programs, movies, Channels in the different servers? ie:
1.rocketserver.tv:35911
2.rocketserver.tv:35922
3.rocketserver.tv:35933
4.rocketserver.tv:35944
5.rocketserver.tv:35955
6.rocketserver.tv:35966
35.rocketserver.tv:35000
40.rocketserver.tv:40000
45.rocketserver.tv:45000
55.rocketserver.tv:55000
60.rocketserver.tv:60000
65.rocketserver.tv:65000
11.iptvrocket.tv:
Hi im using mag 250 emulator (currently not working with the well known issues) and noticed recently i cant get into the inner portal settings has anyone else seen this?And is there a better emulator to choose from? what are peoples opinions and experiences.
