is NFPS epg ninja remote url not working?
I use stalker pvr client so not to sure on other stalkers . All I did was install it , then went to programs and went to menu and addon settings
set it to auto start and rebooted kodi . it auto started and I selected a channel and it played ...
I really don't get that the guide EPG is just gone, I thought before it got that new url, I used a combination of my MAC and sub to pull direct data, wasn't all colorful maybe but service based. Cant I still use that technique in the native stalker from Jarvis or am I missing something. I like grabby chat recommends echo, I just wouldn't think I wanna tie into multiple addons for what in concept was middleware native to Jarvis the service I have for NFPFS MAC etc URL I used before ninja still valid?
Where is the link to show how to make it own guide? Theres only about 10 channels I'm interested in so ill do my own reliable one
Go through the EPG threads. They go way back when the EPG was just beginning, and expatter and kens added information recently. These aren't explicit tutorials, but if you're tech savvy, you'll be able to discover your way to a guide.
Echo doesn't work with Stalker PVR.
I think you are missing a step .
Did you save all your channels to your favorite then 'choose stream' for each channel?
how were you able to map echo channels to pvr? are you using simple client?
Like I said , I installed Echo tv guide
then I set it to auto start in the settings in menu
restarted kodi
took a bit to populate then channels were there
clicked one and it worked tried a bunch all worked
I only have pvr stalker client with an NFPS iptv service
worked for me in that order .....
