Is it possible to have the default channel order changed?
I can't get a custom channel group to persist after I restart Kodi 15. Here's what I do;
- Set 'Use channel order from backend(s)' to OFF.
- Create a 'Channel Group' called Custom in the 'Group manager'.
- Open 'Guide' and the custom group shows correctly.
- Restart Kodi
- Custom 'Channel Group' is no longer there.
I have also tried turning off 'Synchronise channel groups with backend(s)' and switched on 'Don't cache in local database'.
Does anyone know how to get 'Channel Groups' to save after I restart Kodi?
You are 100% correct. I have tried to create Custom Group of channels suitable for my region that work. Easy to do. But it wont save!!! Somebody please show us how to fix this issue
