Iptv66.com issues
13 digits serial and at least 4 digits for device id1 is mandatory.
device id2 and signature 'locks' your credentials and is optional, at least 4 digits too. I would leave them blank for a start.
login/password is your donation.
and for kodi 16.x you need the full portal url for server adress. I understand iptv66.
here it is:
http://mw1.iptv66.tv/stalker_portal/c/index.html
for reference another time you can put your assigned 'short' portal name in a browser to get it.
its just a redirect which the pvr stalker client above kodi 15 does not support therefore you need the url it redirects to.
troubleshooting:
if you put in different numbers while playing around to get it to work and it still does not work:
fill it out as explained above, exit kodi, login to your 'account' (where you change mac address), click iptvreset. start kodi.
first time you will get a authentication error, let it retry and it will load the channels.
after you got channels playing you can move on with epg found on this site. sorry would like to help more but can not right now.
its 5 am and I have a early meeting. :/
just to clarify
The 13 digit number sent to you by iptv66.com is the Username and Password and is commonly refereed to as a iks66 Route number.
NFPS and Rocket use a 12 digit number for this and call it a Donation number. Same thing thou and is Username and Password as well.
The Serial number is something different.
Use the 13 digit Route number whenever it asks for a Donation number or a Username and or Password.
sorry, yeah where it says serial in the stalker client you have to make those 13 digits up yourself. along with device id1, it can contain chars but for the ease of it and not to go wrong I wrote/suggested digits. and donation=route as crazed explained better. :)
thx guys! i got it up and running:D
the only thing i'm missing is the epg guide.
from what i was reading epg ninja removed it from his site..?
but thanks again.you guys were a big help.
only thing left is the guide.
Could someone explain me this if I buy almost 3 donation or iptv66 for 1 year and another for 1 month and I am getting this msg:
Sorry but there is not match with the information provided or your Route expired a long time ago. and all services are login error.... why... this as being a headached.​
