IPTV VOD Ready For Testing!
Look here: http://iptvtalk.net/showthread.php?481-Android-IPTV-STB-Emulator
I'm trying to run Andy and BlueStacks, but its really problematic.
If the "Trial" is working on a Android box using the STB-Emulator, Does anybody knows if the full IPTV service to be offered(the paying one) will be available as well on the android?
The reason is because I have both the MAG254 (already have it working) and an android box, that way I can purchase two rockets...
I've been reading on the FAQ that the only boxes are the MAG250 / 254 and avov.
Ok so Liftoff finally on my Avov!
Here's how I got mine to work. I tested this method several times this morning and worked everytime. I had the server on Server 1and 2. But I don't know if that made the difference. Went to settings clicked on server 1 then on connect. Wouldn't connect.. So what I did is to click on the RED button and keep it pressed for several seconds. You should notice the bar stops scrolling when long pressing the RED button. Then I let go. Did it a second time and third time and on the third try it connects.
Tried it 6 or 7times and works everytime. Try it out and see if it works on yours.
Hope I was able to help. By the way, I didn't use '' http://'' in the server address.
This method works here too. I had saw mine connect once before, but never since that one time. Tried with 4 different slots I had filled in before and all connected fine.
Thanks.
Hope you don't mind but I copied your post into the avov section, and made it a sticky. :)
Thanks toyz4tv, I now have two of my AVOV's connected to the server
That's all part of testing IMHO. We learn more about our toys when they don't work than when they do. Believe everyone should get themselves a sticky- congrats.
follow BIO instruction after Mag250 reboot
Display sreen say
Page loading error
Pleae check conection and the page URL
any one know what i do wrong but i check youtube what be fine with internet
Jlizzotti
I have to be careful after it connects, usually wait @10 seconds after it turns green before exiting out. If I exit clear out of the app you need to start over again every time. If it keeps loading then chances are you lost connection.
I have checked before by exit once and scrolling the movie menu down- if it's not connected it'll exit out and search for connection again.
For me, I had the same info entered in 4 slots and held the red button for @ 10 seconds before going to the next. Slot 2 was the first to connect for me but all connected after. It's finicky about it too, and sometimes you need to let it sit connected for a few seconds before exiting to go into the vod menu. Cursing seems to help.......
IDK yosemite, for me that's how the avov connected. I tried MANY hours before that and that's the fix that worked. The setting tab is the only place it connects for me too, I've left it connecting on the main screen for hours with no connect. I hold the red button down for 10 seconds or so and it connects @5 seconds after I let up. When it connects in the settings tab the dot turns blueish and the bar changes to yellow.
Hope an update comes out the pipe to fix it soon
Thanks BIO, its connected now and the VOD screen populated. Videos are coming in a little weird. Looks like the faces are all stretched. I'll go through some more videos later too.
