IPTV VOD Ready For Testing!
I looked and looked and saw no place to put this post, so I'm posting here. I'm using a MAG254 on the free trial of VOD from NFPS. No real issues so far and patiently waiting for the live TV to start. NFPS has said that all current DN will be launched as well as some more popular BEV channels. I'm keeping my fingers crossed on that one!
What I'm doing in the meantime is seeking out .m3u playlists, particularly one that has working URLS for the Sportsnet package of channels from Canada. Apparently the links for these channels stopped working last month and I haven't been able to find any working ones at all.
If anyone has any working Sportsnet links or knows where to find them, please post back.
Cheers Willy
ASTF I got my jinx wifi unit today and tried it wireless but still freezing too bad to watch on the mag254. The avov is still.running gif lawlessly. It hasn't frizen one time since I hooked it up. In the beginning.
Cheers Willy
just google m3u playlist...
Video output mode -1080p-60. Graphic resolution 1280 x 720. Auto frame rate 24/50/60 hz. Force dvi - off. He I event reaction immediately.advanxce settings. Buffer. Size 15. Gimp version v2. Up np client enabled off. If you need anything else just ask. Thanks
When I went to the inner portal it had a auto update. I told it ok and now that it has updated it seems to be running just fine now. It has not froze in 15 mins which is a record for mine. I will watch and update you on it. Thanks for the info
Must be either the way you have the Internet connection setup, or some external problem set mine up, and it is loading a channel in just a second or two, how long does the blue bar stay up? I have mine hooked to a game adapter, through the cat 5 port too. Check all of your connections first then run the speed test.
