IPTV STALKER Authorization Failed Help
Thanks Dara. I contacted rocket who said they would look into it and this morning it's all working again. I turned off the "send Mac address" cleared cache and seems to be good. Thanks for the advice. Great as always
Dara, got it working perfectly thanks to your help. I did need that stalker client NFPS pvr. I was trying to accomplish it using stalker client which was the problem. Followed the instructions and download link. Thanks for your help once again
Dara I am get thing authorization failed for both of my devices. I have changed my MAC address several times and have followed all your directions from the sticky which is to delete the settings.xml. I am stumped what else can I do.
Same here, I'm running Kodi 14.2 with IPTV Stalker ver. 9.0.19 and all I get is "IPTV Authorization Failed" a did change my MAC twice but with no luck. I cleaned the cache in the stalker but that didn't change a thing I'm still getting the authorization failed, any of you guys get the same thing?
Thank for any help.
in the iptv stalker settings, hit send serial number.. should fix the problem
Thanks for a quick reply, I updated the iptv stalker to ver. 9.0.20 the "IPTV Authorization Filed" is gone for now but now I'm getting "Bad or Missing Serial Number" but there's no box to tick on the modified version of the stalker to send that freaking serial.
You guys getting the same thing? Or should we go back to 1.0.18 ver. of stalker?
Thank you.
@Dara, No defiantly not happy with the situation between Ivue and Iptv stalker as well Iptv just really doesn't work with Ivue (just gives the errors as mentioned). The annoying part about that is I really like Iptv stalker and I really like Ivue, its just very frustrating that its not working together properly!
I tried the PVR for simply client earlier but in all honesty I found it awful so quickly got rid of it. I will look into the thread you recommend earlier and read up and what it says there. In reference to the serial, how do I do exactly? Surely there must be something wrong like a known issue between the iptv stalker working in ivue, can you confirm that is the case or not? As surely I am not the only person having this problem
Also can someone confirm what is the latest version of ivue? As just want to double check that.
Thanks again
dont use iptv simple pvr it is awfull yeah try the stalker one: http://iptvtalk.net/showthread.php?7161-Stalker-Client-NFPS its just as good as ivue or better imho you can bring the channel list up when viewing a channel or the epg to see whats next without going back to the ivue addon you can also zap around like a tv, have the same channel numbers as intended, and more importantly you wont have any issues with the ivue devs have to update it with new channels, fiddle with changing ini files, separate skins etc. I really dont get whats so good about the ivue addon other than its universal and great for addons that can not provide epg?.. but why use it when there is a full fledged stalker pvr client and a epg that is more accurate than ivue and gives the intended pvr experience in kodi?
if you find it dull change the skin and configure it to your likes, it will sure beat ivue both in looks and functionality then.
what am I missing?
pvr: View attachment 1124 View attachment 1125 View attachment 1126 View attachment 1127 ivue: View attachment 1128
