IPTV STALKER Authorization Failed Help
I've got kodi on a kindle fire stick and it wont let me use IPTV stalker, it lets me watch some channels but not many channels actually work?
if I tried opening something a notification comes up saying "IPTV stalker authorisation failed"
I've clear the cache, I've made sure the start to the mac address is correct and the port for it is "http//iptvprivateserver..." (...= I don't know the rest)
anyone have a fix for this ?
Did you pay a donation?
Getting Not Authorized error again.
So yesterday I got the "Not Authorized" error when trying to use the IPTV Stalker kodi add-on. Notice in the announcement section that we need to change our Mac from 79 to 78 which I did and it worked again. Tried to use it again today and getting "Not Authorized" error again?
Did anything change again?
Cache clear does not work.
Thanks for the reply asft and dara but still having issues.
I've reinstalled IPTV Stalker and checked that I'm running 1.0.18 but still getting error.
Weird thing is my mac is working fine through ive guide.
Yesterday I checked if there is a way to check if a mac address is available. Went onto iptvprivateserver.tv and notice there is a mac check funtion, so I tested it with my mac. Now I'm not sure if this could be related to my problem?
Hi Dara,
trying to understand here..
I had tied the mac from my mag to the donation and for the most part the box was working minus all the constant freezing, multiple resets, black screens, etc. etc..
I was also using stalker with the same mac until the last few days when I saw 'authorization failed". During the last few days I also noticed the mag was going crazy with black screens but it would work on some channels some times...
what you are saying now is that if I want to use the mag I have to go to the papiao site and change macs from 79 and 78 when switching between mag and stalker?
please confirm, thank you
Hi Dara,
Yes, that's basically it. The MAGs, unlike the other methods, can send a unique identifier beside its mac to prevent other devices from using the mac. What I think happens is that you relink to 78, and only use it with devices other than the MAG, you won't have that issue. I haven't tested that, but at least you have the backup solution of being able to send a picture of your MAC to the server people to fix it with 79.
so, if I was to send a picture of my mag's "system info" they could add a second mac address with 79 for the box and leave the 78 I switched myself on papiao?
2 macs per donation in my case?
I understand the security concerns but I sure wouldn't like to be the guy doing this manually every time...wow
No, you would only send that picture if you weren't able to switch back to 79 as a recovery situation. They will not give you an automatic switch between the 78 and 79 macs... you do that on your own.
I have the same authorization error too. Running Kodi on Apple tv2 with stalker
Has any body got this connection issue resolved?
Try reading the thread from the top, and use the suggestions listed here. There isn't too much you can do except the following:
-make sure your MAC is properly linked ... using the 78
-make sure you have the right portal url.... that either starts with "portal.iptv*.tv" or "mw1.iptv66.tv" for the IKS66 users
-make sure you do have the valid version of the IPTV Stalker (1.18),
-leaving "send serial number" off
-clearing cache, and if necessary, start with Parental on, with a password.
I am new to this site and have a few questions, would apreciated help of anyone on this forum. I recently purchased a fire tv stick which was essentially fully setup and loaded. I must admit feel bit let down by eBay seller as obviously this iptv stalker doesn't work half the time and it's very hit and miss. Now I have done some research even thou this is all new to me and I gather that iptv stalker are charging and that is big part of the problem I am getting with the dreaded no auth message a lot of the time?
If this is the case, is there either a free way to fix and if not could you provide the details and links on what you would suggest to stop having the issue with iptv stalker. And lastly I noticed on my ivue guide it sometimes uses sports devil and another similar source. Those ones seem to work fine, sadly they don't seem to have many options channel wise. Are there any such alternatives to iptv stalker that have so many channels, looking more for American channels?
Justin
yesterday I have took the donation and linked mac address.My mac address starts with 00:1A;79.yesterday i was able to watch adult channels,Cinema,Music and children rest of dod not open.Evening on wards on every section authorization failed is coming. only able to view VOD section.Now I went to link mac address page and given blank and clicked submit button. now mac address came 00:00:00 like that.Now wants give the same mac address the error is coming the mac address is already exits.But the mac address showing zero only.By the way i have checked on mac address check page it is showing invalid status but in IPSTALKER I am getting 00:1A;79:xx:xx:xx only. Please help me on this issue guys.by the I am using Minix android TV box and kodi pre installed.
