Newbie here
As of 6:52pm Central Time
Using: Kodi Jarvis 16 // PVR - Stalker Client NFPS
After multiple IPTV Reset s -->> Stalker Client NFPS --->> Config --->> does not have option to insert: IPTV Portal address/link. Just MAC address/Donation #'s are same. Keep getting Stalker NFPS Authentication Faild...Retry
I hope above info helps to troubleshoot
Use the pvr stalker client v1.0.3 included with kodi 16 instead.
Enter all required info as needed mac,donation,device id's,serial etc...and in portal 1/server address enter your newly assigned portal being 1,2,3,4 or 5.
EXAMPLE: I was assigned portal 4, so in server address i entered the following: portal4.iptvprivateserver.tv/stalker_portal/c/index.html
You may need to do an iptv reset before using this pvr stalker client because i think the NFPS version sends a unique serial and device info which will possibly give you errors without a reset.
Same here. Just won't load. Goes to server and sits there.This is the solution.... Back up, working, finally.
@jestr
@glenno
portal1.iptvprivateserver.tv/stalker_portal/c/index.html
portal2.iptvprivateserver.tv/stalker_portal/c/index.html
portal3.iptvprivateserver.tv/stalker_portal/c/index.html
portal5.iptvprivateserver.tv/stalker_portal/c/index.html
I should use portal12?That used to be your portal address. That portal is no longer used. Once the Donation Checker comes back up...
https://papiao.is/main/search_nfps
use it to figure out what your new portal assignment is. If you are using Kodi 15, you can use the portal address directly from the Donation Checker. If you are using Kodi 16, you will need to use the longer portal address that I posted in a prior message.
Thus, if the Donation Checker indicates your port address is
Code:2.iptvprivateserver.tv
you would use that in Kodi 15. However, if you are using Kodi 16, you would use
Code:portal12.iptvprivateserver.tv/stalker_portal/c/index.html
No, as I indicated, go to the Donation Checker and see which port address you have been assigned. Portal 2 was used as an example only.
T |
i think i was scammed?
K |
Hope we're getting reimbursed for days wasted
H |
Was working now its not.
A |
Email was closed with donation info. How to get it back?
