https://papiao.is/main/search_nfps
If you are using Kodi and a MAC address beginning with 00:1A:79, you will run into problems. You need to go to the Donation Checker and create a MAC that begins with 00:1A:78 if you are using Kodi.
NFPS Donation Checker:
Code:https://papiao.is/main/search_nfps
========== Edit =============
Was slow responding and didn't see your reply, Crazed.
http://www.miniwebtool.com/mac-address-generator/
when i try to log in there i get donation invalid
and i am using kodi
in my original email i got ----Stopped working after like 2 -3 days
Thank you for buying our service.
We always suggest to use STB EMULATOR on Android.
This is the details to use the IPTV:
Client: [email protected]
Donation N.: ************
IKS Server: 2.nfpsserver.tv:12010
IPTV MAG/STB Emu PORTAL: 1.iptvprivateserver.tv
IPTV KODI PORTAL( Ver. 16+ ): portal1.iptvprivateserver.tv/stalker_portal/c/index.html
MAC: 00:1A:79:FF:3A:77
We assigned a Random MAC address (00:1A:79:FF:3A:77)
to change your MAC Address, please visit:
Regards
Rocket IPTV
Do not post your private information in a public environment. Edit your information, especially your donation number and MAC address.
no worriesi only posted it because it was dead
the credentials above is how you log into papiao to change the MAC
Client ID and Donation number.
However, I did search that donation number and the search comes up empty. It should have been on the system thou, so seems that the reseller has stopped it for one reason or another.
These reseller issues were occurring for a long, long time before the changes a few weeks ago.All these problems started when the latest so called security measures were implemented.
This response"seems that the reseller has stopped it for one reason or another" drives me NUTZ.
save money,save time,save a headache always buy direct never buy from a reseller.This response"seems that the reseller has stopped it for one reason or another" drives me NUTZ.
A friend of mine's sub was stopped after 2 months of service.
He contacted the re seller,and he was given new login info which worked for 2 days.
The re seller would not respond to his e-mails,so he contacted the provider and was told that he should contact his re seller because the re seller
had requested a charge back which was issued so his sub was terminated.
Two other friend's of mine service were stopped after 6,and 8 months.
After no response of their re seller they contacted the provider who told them again to contact the re seller because the re seller terminated their service.
This time the charge back excuse was NOT used because on the provider's own website it is posted that NO charge backs are honored after two months.
Can somebody explain to me what a re seller has to gain by terminating a sub after 6 months or 8 months??????
I can understand a re seller's charge back scam before 2 months,but termination of service by a re seller after 6 or 8 months does NOT make NO sense to me at all!!!!!
All this reeks to high heaven.![]()
Buy from a reseller at own risk !
We have said that since the dawn of time.
I do not know what point or accusation you are trying to make vidswaps, but bottom line is that papiao has no control of these donations boughten by a reseller.
They do not mysteriously delete them from the server.
If they have been deleted by the admistration , then it because of charge backs or some form of fraud with the CC
Contact the reseller to find out. If it was none of his doing then he should respond![]()
I bet he had another 20 people using your login details.... and that stopped so he cut and run. I have to agree the only safe way is to deal directly with the providers.
My friends are all using the Mag254 STB,so I don't think more than 1 person can use the same login details.
J |
some problems about service i think
H |
Tried to renew but was hit by an error page but was charged
H |
is my thinking correct - iptv stalker via kodi vs avov tvonline+
C |
I was up
