I am using emulator 6.11 and this is what I did
how to fix
1 start STB emulator
2 press Menu button
3 select settings
4 select Profiles
5 select Rocket
6 change Serial number to any 13 digits and select OK to save
7 select Device ID (scroll down or it at the bottom of page)
8 select Reset Device ID to default value and select OK to save
9 press return button on your remote to STB emulator main page
10 press Menu button and exit STB emulator
11 wait 1 minute and re-start STB emulator and wait few minutes.
reply if it works.
Thanks.
Works on 0.7.05
I have a question please: I got this working but I can't get it to show more than one channel number at a time. The channel number is at the top left of my screen and all the vids I have seen shows channel numbers running the whole length of the left side. Is there something I am missing to get this function? I wanted a different option than Kodi and this seems like a good option. (I also tried yasem on my windows box but all that gives me is a black screen so I am using the android version on my Minix.) Thanks in advance.
Thanks Thanks Thanks
If you use the mouse in the channel menu you can ad to favorite and sort and what not
Thanks again for your help. Now I have it running perfectly to my liking! :) When I had tried clicking on the items in the past they didn't really seem to do anything, but 'reading is a powerful tool' and when i tried clicking on the colored circles, then I could see where the favourites got starred.
Yippee!
I got emu 7.0.7 working on a mxii g and i did set up kodi with the same mac/sn/ emu 's id and kodi worked but when i went back to emu same old thing
contact your provider. did i miss something?
I do like emu vod all those movies and they have all the info there i dont have to google it is all there but i like kodi too on my laptop i am torn
I can not go back and forth changing mack there must be a better way ????
Bummer about that happening to you. Maybe try it once again with a new mac and make certain to use the exact same info in the emu and pvr. I persevered and got it working that way on my neo. And with this latest Kodi 16 beta5 I can't believe how lightening fast the pvr loads up and the quality of the streams looks much better. So much so that I kept checking to see if it was 720p and was rather surprised that it said 'SD' as it looked that good to me. And the emu looks just as good IMO. I do have 2 donations but use them in different rooms. I originally got the second as a gift for someone but never got around to showing them how to use it so far. Now with my minix neo I think I'll bring it over for them to watch whilst recuperating after surgery and being laid up with nothing to do. Bet they will be quite impressed!
I'm using 7.0.7 as well. Good luck. :)
Wishing you well expatter. I have the time and stubbornness will give it another try. Did you change the id that the emu gave you mine was 50 something #'s and letters
thank you big dady and expatter by the way love you avatar, as for you big dady yours is the next best thing !!! Control !!!
Yes, I used the ID and SN that I used in Kodi. The info on both should be EXACTLY THE SAME or you'll have the issues you are experiencing ATM. It did take me about 7 go 'rounds before I got it working properly. Tks about the avatar; I got it from a Russian forum back when I was using WD media streamers and modded it into WDLXTV. Guess that was about 8 years ago! :)
