How to set up pvr.stalker with NFPS and have a Full EPG
Status
Not open for further replies.
There is no need to change the time zone, the EPG should still be working correctly. Did you change the timeout settings? I think it is set to 60 per default. When I had problems, the timeout happened immediately without any delay. I changed it down to 15 and the loading process took some time, but started working.
Also the EPG is not up to date at the moment, but that is something you can work on fixing once you see channels.
Wanted to see if I could get some help. Little background I have been using Kodi and am very experienced in plugins and setups. I have been using ivue and iptv stalker for around a month and decided to make a donation today. I have since removed iptv stalker and followed the directions above several times. I have verified my mac address is good and uninstalled and reinstalled pvr stalker several times to make sure the installation is good. I got the channels to load one time and since have been unsuccessful as it says " Stalker Client unable to load channels" I am currently on a pc but will be setting this up to work on several fire tv's at home. I wanted to verify it works successfully before making several more donations and setting it up for my family to use. Please any help or suggestions would be greatly appreciated. I have been reading the forum and searching google for nearly 6 hours now and no matter what I try it fails. Please help!
have you tried clearing the data in the EPG?, first turn live TV off, then back on after you cleared the data in the epg, do this a couple of times
Just been helping another member with a similar issue. Hopefully it won't be an provisioning issue, but its possible. See this thread
http://iptvtalk.net/showthread.php?6414-iptv-stalker-and-pvr-stalker
Even though you did get IPTV Stalker to work, it doesn't necessarily mean that you are properly linked at the server, and there isn't much we can do as users, other than to make small changes to the MAC. Even if the donation page accepts your mac, it has accepted known bad MACs in the past.
it will work, just a matter of fiddling around, my epg works fine had trouble with my stalker addon, worked fine on my ipad, not on the android, so after a week or so of fiddleing with the android, I noticed I was missing 2 digits in the mac #, LOL, hours of my life I`ll never get back, simple case of, you look but you dont see
I have tried this again several times. The popup says PVR manager is starting up loading channels from clients and hangs for the 60 seconds. Then it times out and says " Stalker Client Unable To Load Channels"
you`ll have to download the modified stalker client and increase the time out to 60, also on this site there`s a way to even modify that and extend it even more, you might try putting on one of your android devices, if it work there then you know its something on your PC, but dont run both devices with the same donation # at the same time, also i`d try the TV on and off again, and clearing data
Alright I promised an update and after trying everything I have a solution. Apparently it wasn't loading due to something in the cache of Kodi preventing it. I wiped Kodi completely, updated to 15.1 fresh install, Now Stalker and the EPG and PVR are both working! I will do the same on all my other boxes. Service is wonderful we will continue supporting in the future!
Status
