@crazyxbmc. someone posted a pack of Logos here a while back.. You could tell iptv simple client to use those perhaps., may have to do a lot of file renaming though..
Im not going to bother with that.. Something coming soon that will make that redundant.
Sorry, but can you elaborate a little what new is coming?
I ripped these last week when setting up the iVue guide, so there may be a few new channels missing. Worth a shot.
https://m.sendspace.com/file/az3b98
Just ignore the studios folder, that's different. The Stalker logos folder is a direct rip from the server
Wow!!!!!!!!!!! I am totally blown away by all the awesome work being done here. I seriously just had to reschedule an important meeting because I got so caught up reading all this that I didn't realize the time and missed the meeting for today LOL. Huge kudos to everyone working their butts off here.
I just want to clarify.... I am going to be totally wiping my hard drive and reinstalling everything later today. I just wanted to make sure that the original post here has been edited and updated with new info and links so I can just follow those without having to go through the pages here and do the added steps that have been updated as work progressed... Is this correct? Once I get this all set up I look forward to jumping in and helping out as much as I can.
Also, this is off topic... Once I get this all set up on my system I want to be able to copy what I have over to my sister and mother's systems. Is there a backup/copy addon or something I can use for that? If so and someone can provide a link it would be greatly appreciated.
@Shipwreck, the instructions are good, and I adjust them as necessary. As far as copying what you do, it depends on what your system is, as there is a user-accessable folder where your add-ons and userdata are, and you can just copy that over to a similar system that has kodi on it. Read this:
http://kodi.wiki/view/Backup
Basically on a PC it's at "C:\Users\<profile>\AppData\Roaming\Kodi" . Just have to copy that after you install Kodi.
At this time no. the pvr plugins would require an update for that..
It is possibly in future plans for pvr.stalker.
Unsure about IPTV stalker as it uses a 3rd party plugin (iptv simple client) for the pvr, which hasn't been updated in almost a year, so i think its unlikely.
Change your EPG to update to 15mins.
Thank for all the info. Got everything working for the most part. But the epg is not showing any info on the guide. Using the bit.do ... I have reset the database several times and still nothing. Any help?
Change your update of the EPG to 15mins.. Let it sit for awhile and you should be good. Worked for me.
.62 was a post by MetalKettle, which caused versions .7 and above to not be erased. You need to force refresh his repo, or get rid of newer SuperRepo repositories that may have that.
Will removing SuperRepo Repositories disable a bunch of addons included with this Repo as well? Will you need to install it later if you need to enable an addon that is found only on SuperRepo Repositories? Or once it is installed, all addons that come with it is permanently installed. May not be enabled but is installed and just be ready to be enabled once you need to?
The addons won't be disabled; they just won't automatically update, if that repo is the only one supporting it. You may want to look at TR Total Installer, which can help you find add-ons you need. Some of the older SuperRepos, like Frodo All, did not get that version of the IPTV Stalker, and may support some of the more popular addons. You can also find out the authors of your more favorite addons and locate their repos. The IPTV Stalker was just a special case as MetalKettle was getting asked where this addon was, so he decided to put it on his repo, but he also made a few changes on it as people couldn't get it started (or just not patient on the initial load of channels). Before you remove the SuperRepo, you can find out which addons use it by going to the Add-on browser page, and "get Add-on", then finding the SuperRepo, and seeing what add-ons are enabled.
