How to install iVue EPG add-on for IPTV Stalker
you need to be on latest stalker 1.0.18 and also in ivue settings guide fixes delete the addons file then go back into the guide then close the guide and go back in this will activate the new addons file
hi,ivueguide ,this was done using that version number of stalker,also did all the fixes and it worked better but when a channel wasn't showing up and option to select stream appearered iptv stalker was not showing as an option for stream choice,it is now working better but still a few niggles with a couple of channels and also channel logos seem to be loading very slowly
It seems like I too like many other are having problems with stalker right now
Only the music channels are working for me right now. Everything else isn't
PVR Stalker version is 1.0.18
Running Kodi 14.2 on FireTV
I've attached a snipped of my log file that seems relevant to the problem
http://pastebin.com/YEZzKN4N
I have completed the move to the new server guys and it is working So fast now. all issues should be resolved and i will now continue looking at adding channels etc thanks
looking really good again ivueguide,running fast as well as you say a few channels to sort out and it will be perfect great work from you and the guys who put the stalker iptv together/up and running,thanks for all your hard work
Ivueguide, first I will to express my appreciation for all the work you have put into this guide for the community; I am sure all here feels the same.
I have the guide running from before on my M8 box; I then did another installed on my iOS device, from the link you posted here. It installed fine under Programs, but when I tap on it to open it does not. This is just on the iOS device, not the M8.
I have removed the source repo and uninstalled the guide reboot and reinstall it again, but same thing.Am I missing something?
Ivueguide, a minor request... can you find a regular "Fox" icon for the Miami (and NY) network channels instead of "Fox News"? Also, I'm not sure why, but if you select "Delete Guide Data Files", I keep seeing the notification that it was cleared, over and over again.
I was just about to post that very issue Dara. I assumed it was because it was deleting more than one xml file, but not sure......
I can't be sure, but maybe the add-on is attempting to delete stalker.xml, but it can't, so it keeps on trying, but is stuck in a loop until it tells you that it can't, eventually. I avoid using that option, and just clear those out manually if I want to retain settings.
I'm using Kodi 14.2 with Ivue version 6.0.22
When I run Ivue. The screen comes and displays " No program available" for all channels.
Anyone has the same problem?
I'm not. I suggest trying to reset the guide data, which may get you a bunch of messages that you have to acknowledge, or just resetting the entire thing and starting over.
The NFPS server is down, and will be for up to 24 hours while they fix it. Ivue is saying no program availbile likely because stalker client isnt able to connect to the server properly.
Ivue server is fine just goto program addons press c on ivue tab then goto settings in there youll see guide fixes run reset database top one and that should sort it
And dara is correct we pull via webgrab to our own host and link to lots of different addons so it doesnt effect the guide if stalker is online or offline thanks
How do you upgrade to iVue 6.0.22? I'm stuck on 6.0.19 and while it reflects that there is an available update it starts to download for a sec and then stops. Also tried the mucky duck repo and have the same outcome.
Ps. Thanks for the awesome addon!
I'm using Iptv stalker with the epg that's configured in my pvr client can someone tell me the general settings for live TV general setting am I suppose to highlight the area use backend ch numbers (only wrk with 1 enabled pvr add on) should I have that on??
