Freezing and looping question
I have been watching CBS News for over 1 hour and 20 minuets now and you are right kens. NO buffering and No Looping.:o Looks like that channel is in 720 i.p. also.:o Not even a little quiver. So it must be something else on the other end. Thanks kens .. andkaal:rolleyes:
The main problem right now is the HD channels are all converted up to 1080p from what looks like mostly 720 sources.(they used to be at 720 until they made the changes). All STB's etc. have no problem decoding 720.
It is the decoding of 1080 that is the problem, apparently with varying levels of success.
SD freezing at peak times to!
Over loaded servers plan and simple!!They will keep adding donations until the servers are full, then and only then
they will add another server and it will work flawless until its full, and over and over again we go.They will never keep room
for peak times and weekends not when the almighty dollar and donation room is available.
To bad it did run smooth at one time,but can't keep waiting for it to get better I for one won't renew this time even if it is cheaper.
Products used could of paid couple months cable or more over a 3 year period.
Mag254
T1plus
X96mini
FormulerZ7plus
Fiber internet so no it's not that.
Mag254
T1plus
X96mini
FormulerZ7plus
it's amazing you think it's not your internet
you could have 300mb's d/l and it still could be your internet
For a month or so, Rocket has had issues. Freezing and buffering and even going off. But just now it has been working great. HD channels are even better. Buzz 3000 works super, and you can't beat the price for what you get with Rocket. Hope it continues now for a good while. You can't beat the price for what you get. If you are having problems "IT IS" your internet.:rolleyes: It is working flawless for 6 days now. So if you are having problems now, it's on your end. andkaal:rolleyes:
You should not overlook the weather.
Just like 2 weeks ago with the Hurricane etc., a "Nor' East'r" weather event is happening in the US, that will most likely affect many stream sources or cause Internet traffic to be re-routed due to power outages etc.
Just a thought...
ps; Some US channels quality has been noticeably intermittent for ~2 days (East Coast, P1, P3)
