Does it matter what server address you use?
Have done every thing by the book and can see channels load ect but cant see the app to click on it am using wookie retro build.
I have a couple of questions/
1. Currently using IPTV Stalker but would prefer to use Stalker Client. Therefore should my first step be to disable or uninstall IPTV Stalker?
2. The first step in the instructions "1. Get a new Mac Address from server.", where is that referred server?
NFPS: https://papiao.is/main/search_nfps
Rocket: https://papiao.is/main/search_rocket/
IPTV66: https://iks66.tv/main/search
http://www.miniwebtool.com/mac-address-generator/
wow...you guys are the best!
Thanks to your help and guidance I finally got the Stalker Client working.
In the video I noticed that there is information displayed for the current TV program on each channel. How can I get that same info working on Stalker Client?
I found how to display the EPG info...in the configuration of Stalker Client I changed the Guide Preference to Prefer XMLTV.
Its not working.
OK all fixed. Issue is new serial numbers needed. Found a fix. Thanks dafatmack. For all those running Kodi and Stalker Client.
2. Go into Kodi and turn off Live TV, and clear data. (I always clear two times to make sure.)
Go into system, addons, PVR clients, and disable Stalker Client.
Go in and configure Stalker Client, and make these changes.
1. Change Mac Address to new one.
2. Make up and enter Serial number: any 13 digits
3. Make up and enter Device ID: any 4 or more digits or letters - I used my device name
4. Make up and enter Device ID2: any 4 or more digits or letters- I used my 2nd devices name (phone)
5. Make up and enter Signature: any 4 or more digits or letters- I made up something special to me
Enable stalker client 0.8.3.
Go back and turn Live TV on. I needed to do this 2 times.
Now you are up to par with the new security. If you use your Mac address for more than one device all info must be entered the exact same. Remember to never use the two devices at the same time.
17:44:40 T:1869633416 ERROR: PVR - PVR_ERROR PVR::CPVRClient::GetChannels(PVR::CPVRChannelGroup&, bool) - addon 'Stalker Middleware:http://11.iptvrocket.tv/' returned an error: server error
17:44:40 T:1869633416 ERROR: PVR - PVR_ERROR PVR::CPVRClients::GetChannels(PVR::CPVRChannelGroupInternal*) - cannot get channels from client '1801': server error
17:44:40 T:1869633416 ERROR: PVRChannelGroup - virtual bool PVR::CPVRChannelGroup::Load() - failed to update channels
17:44:40 T:1869633416 ERROR: PVRChannelGroupInternal - virtual bool PVR::CPVRChannelGroupInternal::Load() - failed to load channels
17:44:40 T:1869633416 ERROR: PVR - bool PVR::CPVRChannelGroups::Load() - failed to load channels
17:44:40 T:1869633416 ERROR: PVRManager - virtual void PVR::CPVRManager:rocess() - failed to load PVR data, retrying
1 |
kodi installer for those in need of help.??
L |
For those getting "Not Authorized" error all the time
J |
TVMC for Android Finally Updated
M |
Easy EPG with no effort for the IPTV Stalker client!!!! "NFPS LIVE TV"
