Fixing iVue Guide to work with IPTV Stalker ("failed authorization")
Status
Not open for further replies.
Since stalker updated to 9.0.19 I've had to change the MAC everyday to get it to work, I only use my mac on one device.. Its starting to be a ball ache, it never happened before. Is there any way to fix this problem?
No MAC address in my addons.ini
I pulled it using adbfire. all I see in Notepad++ is channel lists. anyone else run into this?
nm I went back and read again and now I understood everything beter. although using the modified IPTV Stalker I get authorization failed errors.
does anyone have a definitive answer for getting a guide working? or using Stalker Client instead which has a fully working guide?
Go here to find out how to fix your settings.xml ... look at post #2.
http://iptvtalk.net/showthread.php?7379-Modified-IPTV-Stalker-(9-0-19)-iVue-compatible
The object here is not to have your mac in the addons.ini, but in the add-on that is being called. You'll probably need a new MAC as the old method prevented use of other add-ons, like the Stalker Client, due to the the psuedo serial number being associated with the old MAC.
I'm too lazy to do this, I've managed to obtain a copy though of my addons.ini
Can somebody who is legit input the necessary mac info into the new addons.ini so that i can just copy it back into kodi?
That would be great!
Make it easy on yourself... use the iVue compatible IPTV Stalker 9.1.19 which will use your uncorrupted linked MAC. The iVue guys previously had to put in a dummy mac into the addons.ini so it would continue to work, but they stopped doing that, because it required people to modify that addons.ini to make the call back to IPTV Stalker.
Suddenly stalker isn't working at all for me in ivue, keeps saying serial number issue. I have read what you posted but really not clear on what I am supposed to do and why it "suddenly stopped working". Looks like I am on 0.19, so if I need to update to this new 0.21 (which repo is it listed in) and secondly where do I get this serial number exactly? Thanks
Status
