Bkman2020 Desert Storm Fire Rescue 2K 10 Years 1K Days Dec 17, 2014 2,950 29 48 Android World Feb 5, 2016 #21 Feb 5, 2016 #21 No issues here with the epg on my windows 10 laptop using the latest kodi build.
ilan Moderator at Work Fire Rescue 2K 10 Years 1K Days Sep 29, 2015 8,641 67 0 Celestial Fields Feb 7, 2016 #22 Feb 7, 2016 #22 Are there issues with the guide at the moment? It loaded fine yesterday, but this morning I'm getting "No information" for all channels.
Blackbear199 Blackbear 10 Years 1K Days May 20, 2015 552 6 0 yes i do Feb 7, 2016 #23 Feb 7, 2016 #23 what 24 or 72 hr? i just cleared everything and loaded the 72 hr and its fine.i dont go through papiao auth(i log into server and download the file and load it as local) though so it may be causing issues.
ilan Moderator at Work Fire Rescue 2K 10 Years 1K Days Sep 29, 2015 8,641 67 0 Celestial Fields Feb 7, 2016 #24 Feb 7, 2016 #24 72 hour - NFPSF3 After first No info, I cleared the data in TV and Guide and reloaded, but still ended up with No info for all channels. It just zips through loading the guide from client in 5 seconds. Thanks, Blackbear ==================== EDIT If I switch to Prefer XMLTV, I get the guide, but that one is always off by an hour. Last edited: Feb 7, 2016
Blackbear199 Blackbear 10 Years 1K Days May 20, 2015 552 6 0 yes i do Feb 7, 2016 #25 Feb 7, 2016 #25 ya,the papiao authorization is still down.
ilan Moderator at Work Fire Rescue 2K 10 Years 1K Days Sep 29, 2015 8,641 67 0 Celestial Fields Feb 7, 2016 #26 Feb 7, 2016 #26 Ok, thought something was up -- or down in this case. Thanks, Blacbear...
G gabby4chat New member Feb 19, 2016 66 2 0 yes i do Mar 13, 2016 #27 Mar 13, 2016 #27 If off by 1 hour go into the epg update configuration and un-check time offset then guide will be fine
psycon enlightened one Feb 25, 2015 11 11 0 In the hills Mar 13, 2016 #28 Mar 13, 2016 #28 this thread talks about a something that isnt used any more. closing.
