EPG for US and UK Channels
thank you expatter for all the info, re VOD, would that mean the provider like rocket is no longer offering VOD or is there another way to get it within kodi for rocket
^What ilan said.
Sorry, I thought you were asking if there was an epg for VOD (there isn't). In addition to above, if you use the playlist option and simple client, you can have VOD from the pvr, however using potato is a good way to go for VOD.
aCiDjEsUs - thanks so much!
I was using yayahbell and was hoping it would fix itself or come back to life, but it became apparent that wasn't going to happen. I came here and found your thread right away - the GitHub link worked for me!
Cheers!
For those who are just tuning in, here are the two resources for Acid's EPG.
http://acidjesus.tk/guide.xml
https://raw.githubusercontent.com/acidjesuz/EPG/master/guide.xml
Just a note...
Acidjesuz switched to github due to the slow download speed of the european .tk Server.
Use the 2nd URL and disregard the 1st. ( * 10 seconds compared to 2 1/2 minutes ).
Hey All,
Great guide and work. Appreciate it. I've been using this xmltv file with TV Guide Fullscreen. All was working well until yesterday. It seems the xml file has an '&' symbol which is causing the xml parse to crash. I've narrowed the issue down to the line of code below. I have managed to manually fix the file but was wondering if the source file could be modified.
    <channel id="I167.24657.schedulesdirect.org">
        <display-name>Discovery Home & Health</display-name>
        <display-name>167 Discovery Home & Health</display-name>
        <display-name>167</display-name>
        <icon src="https://s3.amazonaws.com/schedulesdirect/assets/stationLogos/s24657_h3_aa.png" width="360" height="270" />
    </channel>
Hey All,
    </channel>
Thank you for the heads up.
Fixed, should be fine on the next pull.
Thanks for the guide. It works great but I can't get it to recognize my time zone. I have changed the time zone to -8:00 in IPTV pvr client but the EPG does'nt change time zones. Any suggestions would be appreciated.
On my box that has 16, I have to offset -5 to get correct epg for EST but not on other installs that have 17.6.
Yes, but he was off by 8 hours, and he had the setting at -8, so I thought a 0 setting would probably get things straightened out. I didn't think it was a coincidence.
Kodi has changed how it responds to the offset and how it responds to Daylight Savings Time. Both changes have been in the positive direction.
