EPG for IPTV66, NFPS & Rocket
That link now redirects you to kens epg.
You should use the direct url;
https://raw.githubusercontent.com/kens13/epg/master/guide_ks.xml
Rebrandly links for a "free" account, will stop at 5000 access's per month, then will stop redirecting.
alternate EPG is available from the Provider.
Use;
http://(your portal url):80/xmltv.php?username=(Donation#)&password=(Donation#)
Hi
I share my guide for IPTV66, NFPS & Rocket
does not work in kodi
[COLOR=#333333]http://kokaleka.tk/epg.zip[/COLOR]
Enjoy ! ! ! !
Great guide Terry.
* If you save the file using gzip, all applications (including Kodi) can access the data.
instead of link to epg.zip with compressed file epg.xml, you will post a link to epg.xml.gz.
Here is a Link to the gnuwin32 package, that contains gzip (plus other utilities) (Windows version)
http://www.mediafire.com/file/26o19c3ph7f70x7/gzip-1.3.12-1-setup.exe/file
just switched back to pvr stalker in kodi 7.6....is there a working epg guide as of today ? would appreciate any help and thanks.
In Stalker settings, if you set EPG source to "Prefer Provider", it will try to get Providers guide first, and if there is a problem, will get the XMLTV source (if one is entered).
If you set to "Prefer XMLTV", it will try the alternate source you enter in the Remote URL, and if unsuccessful, will try the Providers guide.
- so -
**Disable PVR Stalker
in Portal settings;
-Set to Prefer XMLTV
-Set to Remote URL:
URL Address :
[COLOR=#333333]https://raw.githubusercontent.com/kens13/epg/master/guide_ks.xml[/COLOR]
Save settings by clicking OK *(Do not Enable Stalker yet)
Go to System Settings/PVR&LiveTV/General tab
- click Clear Data and confirm by OK
Now go back and Enable Stalker.
*Note: it may take a number of clear data attempts when using Stalker.
there are two fields to be set iptv extreme:
one says "insert channels link" the next says insert EPG link
do you know how to do it?
For EPG link enter;
*iptvxtra.xml is for use by IPTVXtra2 on KODI
Channel Link would be the m3u playlist link in the following format(replace with your Server and change DONATION to your account id);
http://[B]p1.iptvprivateserver.tv[/B]:80/get.php?username=[B]DONATION[/B]&password=[B]DONATION[/B]&type=m3u_plus&output=ts
that did not work. if you have the time pls take a look at
and let me know if that portal can be used to setup an EPG, looks like that is the intention. the app is great, better than Stb and allows recording (without watching) which is great for stuff that is on during the day and does not replay (like sports events).
this is a support site for nfps/rocket/66 not extreme ....
sorry, error in the channel link url;
get/php? should be get.php?
Mis-understood, ...Sorry!
To get Providers EPG guide;
http://YOURPORTAL:80/xmltv.php?username=DONATION&password=DONATION
There is a setting which downloads the provider epg automatically, so maybe I what have now is the provider epg. channels start from zero and there are no groups. i would like to have an epg like in stbemu where I have a sports category/group. also there was a VOD section, now I do not see where the VOD has gone,
I will try with perfect player and if that works I can use PP for watching and iptv extreme for the occasional recording only.
so, what should I try to get an epg with groups?
I think you are assuming the problem you are having, relates to the EPG.
Categories or Channel groups are specified on the Playlist, not the EPG.
Do you have a MAC# linked to your Account (from the stbEmu app)?
Extreme & PP use m3u playlist or XC access to connect to the Servers.
*(so remove the MAC# on your Account)
Perfect Player setup method >http://iptvtalk.net/showthread.php?...ect-Player-using-my-PP-Settings-Template-File
