EPG alternative with USA, UK and MEX channels
Unfortunatly im not using these iptv provider anymore, too slow and the channels always hang, i changed provider.
I payed for the service that provides the bulk epg but it expired a week ago, if somebody wants to pay for 1 more year i can set it up again but im not paying it since i dont use it
Regards
how much is it ?
When I use SD-Json, it gives me a "Error ....... : TCP 124363R 124356H" message. I've tried everything. I said forget it. I just use my batch file for mc2xml with the standard SD command for what I've selected for the U.S and Canadian stations through schedules direct. Then I use xml merging software and combine both xml files with mine and Kens pull.
When using SD-Json does it require a certain version of windows? At this point, I tried all the helpful methods in the forums awhile back...and I'm pretty much clueless as to why SD-Json pulls fails when it tries to download and create the xml.
Nah, it doesn't require a certain version of windows. SD has an announcement on their website that their downstream providers for Great Britain changed some things so they had no choice but to also make some changes. Just run the mc2xml like it's the first time and put in GB and just use the partial postal code they use as an example in the interface (SW..) and get the list of providers. I used to use BSkyB and now I use Sky HD - National (National). Just pick the provider and let it run to get the new channel IDs and simply change your batch files to reflect the new numbers/IDs.
I think the changes went into effect December 17th or something like that.
The JSON Sched Dir service migrated to new grabber zz_sdjson
*Info;
DESCRIPTION
This is an XMLTV grabber for the Schedules Direct
(http://www.schedulesdirect.org) JSON API.
tv_grab_zz_sdjson - Grab TV listings from Schedules Direct SD-JSON
service.
Thanks Expatter...It's now working. :)
Just BTW...
Received 10 donations.
This covered the Hosting Subscription and the Sched. Direct subscription costs for 1 year.
Since I cant be a pr%*k, I left the guide accessible to all (but it has a donate message in the descriptions)
Users who have or do donate, get the link to the same guide(without the support message).
I just couldn't do it!!
Post more info please!
What program and platform(android/pc/stb/fireTV/ etc.)?
Android box, fire tv and pc windows 7. When I entered your xml I didn't key in every letter and number. Instead I plugged the link in the browser and entered it. Then when it populated I saved the page as an xml and used that instead. I'm under the impression that it should work either way.
I don't know what you're using to stream the channels, but if you can add the guide's URL to the client, it makes life easier. The guide will then update automatically. If you choose to download it, you'll have to keep on top of it, since guide data will expire.
I didn't think it mattered because all that same info is in the xml file. Am i missing something here?
