Dreamlink T3
would luv to try this box Dreamlink t3 they make great boxes
Hisilicon HI3798C V200 is a new hardware solution based on ARM Cortex-A53 cores, has a good cpu with excellent multimedia support. HI3798C V200 is equipped with a GPU Mali-T720 supports HDMI 2.0 output up to 4K at 60 HZ, 10-bit HEVC / H.265 and VP9 video decoding at 3840×2160 resolution at 60 fps, and integrates SATA and USB 3.0 interfaces.
Hisilicon can provide Android 5.x and Linux SDK for the processor. HI3798C V200 will target Ultra HD set-top boxes (STBs) for the DVB, IPTV, and OTT markets, and Hisilicon claims it is the “first global Ultra HD STB chipset solution to support Dolby Vision high-dynamic-range (HDR) technology.”
Hisilicon Hi3798C V200 main features:
CPU – Quad core Cortex A53 processor (15K DMIPS)
GPU – ARM Mali-T720 supporting OpenGL ES 3.1/2.0, OpenVG1.1, EGL, and Imprex 2.0 PQ engine
Memory I/F – DDR3 or DDR4
Video Engine (VPU)
Codecs – HEVC, H.264, VP9, VC1, MPEG2
Decoder – 10-bit up to 4Kp60
Encoder – H.264 @ 1080p30 or dual 720p30
HiVXE 2.0 video engine supporting 4Kp60 H.265 and VP9 decoding, 1080p PiP and video transcoding
Dolby Vision & HDR10 for “best-in-class video quality experience”
Peripherals:
Video Output – HDMI 2.0a TX with HDCP 2.2
Connectivity – Dual Gigabit Ethernet
USB – 2x USB 3.0 ports, 1x USB 2.0 port
Storage – SATA and 2x SDIO
Transport Stream – 4x TS In + 2x TS In or Out with support for Full-band Capture (FBC) tuner
Expansion – PCIe
Security – Advanced DRM and CAS, Trustzone, Hardware based video watermarking
thats chip set right
The box is fast!, I just tested it out over the weekend and its blazing!. Mol2 is way better than dol2. Channel changes are within 1 second or less. The PPV section was still not working. Might be in progress I think.
What I did notice is that when watching the boxing fight over the weekend 455 would freeze, then I would switch to 456 and nothing. All the channels were black. I would turn off the box and back on and then it works great. There might be a buffering bug with 1080P streams or higher quality streams. Can anyone verify this? Maybe I did not give it enough time to reload or something...
so z8 is same as t3 ? is that true
yes, almost the same except they use their own separate firmware updates.
Otherwise the same, yes.
The Z8 with the MOL2 has been available and tested for 4 or 5 months now I think. which has given them time to have worked most of the bugs out now, any that mattered anyway.
Not only is the MOL2 an improvement but the User Interface and the box setup is been revamped from previous models too.
Yes and even all the previous boxes are the copy of each other.
But with this one, they going have this possible to record on one channel and watch another channel or YouTube, Netflix etc which I think Z8 hasn't announced it or not even sure whether Z8 will receive that update or not...
may Z9 will do it :)
And + 1 another new feature on Z9 and then you'll see the T3 prime coming soon and so on....
So better buy T3 and start watching.... I think this box has everything you need and its very fast compared to other DL boxes.
you run z8 ?i know cap has one and he likes it
yes, I was part of the alpha/beta testing that took place for about a month before they released the model.
One important improvement with the T3 will be seen in how it handles m3u playlists.
Those that do use these m3u playlists, will enjoy how the T3 or Z8 is setup for Playlist functionality:)
I know Dreamlink are one of best have few of them never had z8 and what i hear about the T3 this should be a fine box to get like all other ones would truly like to see how it handles 4k with hdr
Yes its fast. I went from a T1 PLUS to this and its Day and Night. For anyone with boxes that are not T2 Prime, T3, Z8 or Z7+ I recommend this ASAP. Will give you less headaches...
I have notice with my T2 / Prime, whenever I reboot it and after the portal loads, I sees EPG being downloading on the top right corner
But with T3, its not happening and I usually EPG not appears until I start watching the channels.
Does any one notice this ?
yes, that is normal with the t3 and z8 , as far as I can tell
