Down for 3 days
I get a no internet connection on kokaleka, I?m assuming it?s because of MAC address? I don?t want to screw anything up, I know I have to do it on rocket page do I just hit change Mac? Thanks crazed
yes, when you log onto your code at the Rocket site and where the MAC is displayed , use that Change MAC option and then simply highlite the MAC and delete.
But before you do that I can change that portal for you, but I'd need your log in credentials.
Changing the portal has been reported to work for some members.
So you can go ahead and delete that MAC and try the Koleka and then later we can try changing the portal with that MAC re-attached. Or we can do it tonight.
I'll bee here a few more hours so let me know if you see this and what you want to do... Otherwise I be back online tomorrow afternoon some time.
Got working on Kokaleka tv. Using buzz vidstick. Follow crazed directions worked perfect. Thanks crazed
oh okay great work .
I had just made a new post in response to your last (see above).
When or if you want to try changing your Rocket portal let me know and we can get it done, but check out how you like that Kokeleka app first.
And
If or when ever you may need assistance with that, I'll be here all year :)
You have to get mod or paipio to change portal on there end I think? Otherwise the kokalola tv app is easy to sideload onto your machine and easy to use. Just scroll back to crazed post on it! Been going strong since I installed it last night.
So following this thread & downloaded Kokaleka app,did an iptv reset & got it working & then went back to the tvonline app on the T3 & low & behold all the channels that weren?t working before are now working again - fingers crossed that it stays working.
thnx guys and gals.
I didn't do it all really much at all, just showed you what i knew really is all I did and some contact with admin, but again just reporting. I know how important it is to get a response, as oppossed to crickets :)
Yous all stuck in there with some reports and etc too... Even the changing portal was reported not to help by a few on forums and in my PM inbox and my own testing as well. But then after it did help. Yous all did that reporting work.
What I really wanted to let yous all know as well is ...
Ryu would have normally been here and some of us may have noticed he was not. It's cause he is aboard, home with his family over the season. Should be back soon :)
