We do know that the server has been up and down in the past 24hrs.. So with that said I wouldn't change anything at all and wait to see if it comes back up working. Mine was down an hr ago when I turned it in, I waited 15 min or so then retried it and it was back up. I didn't change any settings and just retried to connect..Agreed... as you can tell I am not the only one with the issue. So something is off somewhere especially if we are connecting to the same server and i doubt its on the user side.
Some are up some are down... All you can do is be patient, posting your still down over and over does nothingI am still down and i did not made any change.
Your new and I guess you don't understand yet how this works... You will be down and miss El Clasico unless you have a backup TV source like many of us have... You posting your down over and over does nothing to speed up the server being brought back online!Down...... and no El Clasico.........
Yes, IM having the connection problem with my STB emulator specially in the morning, and sometimes during the afternoon, connected perfect for a few times and then it wont connect. My internet is 300 mgps very fast. Any other program in my android work a 100% is just the stb emulator connection always the proble, I reset my donation and start working again but then start having the same issue. I was wondering if it is the server problem??
so are we down or what? I wish the staff would just make an announcement when the whole server did down. I was running great a few days ago and now all I get is a black screen!
U |
portal connection error
Connection
J |
Connection Problems
Important --- Server connection issues
