BuzzTV xpl2000
THANK YOU SO MUCH for doing that. Omg I had no idea it had such an EPG. I'm really intrigued now, and may end up picking this bad boy up. I think I may end up going with this box rather than waiting for the new Dreamlink box in June/July.
Seriously, thanks again. I'm sure many folks wanna see those photos. :D
EDIT: As others have said, I sold my T1 due to the abandoned promises that were made. I loved it, but I refuse to support a company that deceives and gouges its customers for money. At least that's my point of view.
I look forward to trying one of these bad boys. It looks pretty epic. Has there been many/any system updates since you guys have received your boxes?
Cheers!
yes it is really a good epg. yes there has been a few updates to fix bugs, they are very good to deal with and solve problems very fast! the box itself is faster then the old t1 and is pretty seamless channel changing/surfing, vod and stuff like that. very impressed with it. it is worth trying out forsure.
I was dealing with the org t1s and they left a sour taste in my mouth with this whole new box and lack of upgrade to it and a new box already in the works.
any other questions just ask away!!
That's absolutely beautiful! Thank you very much for posting this info and photos. I'm sure many folks will be interested in the box after seeing that.
And the Google PlayStore works as expected?
I think I'm gonna get one. I already own a few s905 boxes from beta tests which is why I've been holding off lol.
Cheers!
EDIT: I forgot to add that the device uses a s905-b Soc which if I remember correctly, has a bug in the hardware decoder for 4K 10 bit X265(HEVC) videos. No IPTV sub uses X265 anways, and if you don't have a 4K TV , you got nothing to worry about. If you watch a lot of "4K 10bit X265 videos" , you may have issues with playing them smoothly. Just something to be aware of.Software decoding should work perfectly fine however (if the box can handle it, which I'm not sure of)
I picked up an XPL 2000 on Saturday and have a few minor nits/questions. When playing VOD from the iptv provider, content is stretched vertically to fill the window rather than being shown letterboxed - is there a way to correct this? There does not seem to be a setting to change this - has anyone else found this? Content is shown correctly through Kodi 17.1 on the Buzztv but not through the VOD selection. Also, the rewind feature on live tv accessed by pressing right arrow on the available channels (shown on the grid with a double arrow) does not function for me - it crashes back to the Buzztv homescreen after showing a calendar of recent days on the left side of the screen - touching the calendar leads to the crash to homescreen. Channel changing is largely smooth and fast - I've encountered minor freezes when switching to channels that aren't active at the moment where the system won't switch to another one until a long time out occurs - not sure if this is consistently happening. The google playstore is accessible and largely works - be careful for mobil vs tablet or tv formatted apps.
Otherwise, the XPL 2000 seems to be working fairly well. The interface is quite clean and responsive.
  • Like
Reactions: crazed 9.6
I've been interested in the reason for the VOD being stretched vertically on some letter-boxed content - again I'm not sure if this is provider specific as I've only tested this with one provider. But I have "crashed" the live TV app a few times back to the VLC player settings menu which suggests to me the Buzztv app is built to use VLC player (which does the automatic stretching if used on android apps like flawless tv but not if using mx player). It is possible that the VLC player settings appearing is an artifact of something else I've had running earlier but perhaps there is hope for adjusting a default setting here. I'm going to see if a higher bitrate provider (with servers topologically closer to me) improves video frame rate - non-iptv sources like Netflix or related stream flawlessly - right now the system is working pretty well.
I haven't managed to crash the buzz tv application except a few times when holding the up or down button to scroll through channels using an aftermarket airmouse remote. In each case it crashed back to main screen and not VLC. I've tested with 5 servers and all seemed to work great except for one which could not connect. Channel change speed varies from service to service. tv catch up function works flawlessly on the couple servers that truly support this option.
That's interesting - can you let me know an example service that supports catchup?
I've mostly experimented on ----STAFF Edited---- did not think to try this on a yyy evaluation that expired. I can crash back to the desk top by trying to select catchup on ..... When in the live TV app, I pressed menu on the remote and a window appears on the side with a list of choices - below a horizontal line in that menu is an option that is "Settings" (also update and a few others). I was trying to access that selection using both the provided remote and a mouse remote - it seemed to be available very briefly after the window appears but is not selectable after that. After trying to select Settings a few times, I opened a channel and hit the filled square button (full stop on playback) and crashed into the VLC player settings menu. Is VLC in your Apps directory? I'm wondering if it got dragged in for me as a dependency. I installed the Flawless android app and that prefers VLC as its player - possibly that's where it came in - I switched the zzz android app player to MX Player to fix the VOD stretching problem in that app and was hoping something similar might exist for the BuzzTV live app.
I'm reasonably impressed with this box so far.
I've mostly experimented on XXX - did not think to try this on a yyy evaluation that expired. I can crash back to the desk top by trying to select catchup on Epic. When in the live TV app, I pressed menu on the remote and a window appears on the side with a list of choices - below a horizontal line in that menu is an option that is "Settings" (also update and a few others). I was trying to access that selection using both the provided remote and a mouse remote - it seemed to be available very briefly after the window appears but is not selectable after that. After trying to select Settings a few times, I opened a channel and hit the filled square button (full stop on playback) and crashed into the VLC player settings menu. Is VLC in your Apps directory? I'm wondering if it got dragged in for me as a dependency. I installed the Flawless android app and that prefers VLC as its player - possibly that's where it came in - I switched the Flawless android app player to MX Player to fix the VOD stretching problem in that app and was hoping something similar might exist for the BuzzTV live app.
I just picked one of these bad boys up for a pretty great deal (less than 100 CAD). Should be here sometime next week. I look forward to putting it through its paces and seeing if all the hype is warranted.
I hope it turns out to be a good box, and not a novelty!
Cheers
I can now confirm Munstah's comment about the catchup feature working correctly when on a server that implements it correctly. Also, frame rate issues seemed to improve a lot. Also, the settings menu on the menu pull-up in the Buzztv app calls up the server selection panel - not video quality.
I got mine today. IT IS SO SO SMALL, omg haha. Way smaller than any of my other boxes. It makes a MAG look huge
It comes pre rooted. Setup SuperSU and updated the su binary - check. Nice thing with this is, you can change the UI/layout and switch to a new launcher (and remove the old ones) if you prefer.
So far the Android firmware seems fairly stable. Much better than typical "android boxes". Only "BUG" I have noticed, is if you uninstall an app that came with the box (ex. kodi), when you reboot, it reinstalls the app you removed (kodi in this example). This should be easily fixable seeing as we have root access. (I think this is the INTENDED idea, hence not a bug)
Full Aptoid and GooglePlay Store access - no issues here.
WiFi seems to perform pretty good. The box is very snappy and quick.
I would advise all those who get the box, to turn it on, and update it immediately. Then do a full System reset, and then setup the box the way you want it.
I will update more when my Stalker sub becomes active.
Cheers!
Tested a few more things after getting Stalker setup.
IN STALKER PORTAL:
- Refresh rate switching does NOT work
- Channel changing is very fast
- Video quality is hit and miss. Some things look really good, but I'm noticing almost like a shake/blur in the background (unfocused) part of the video. Some things look worse than my MAG or dreamlink - same IPTV server
- Noticing almost a "motion blur" - similar to low bitrate streams
95% of the testing was done with VOD content in order to reduce the chance of mixing up the above symptoms with low birate streams. It could just be due to the indivual server I used, but I don't think so. It worked great on my T1.
There will be more to come. I won't be able to check many other stalker servers (costs $$). I will definitely test this server a lot more when I get a chance.
Cheers
Hi Veronicas.
Please help i am not able to setup my stalker portal. As soon i hit server it takes screen showing Mac address user not found. Not sure what i am doing wrong here:(
Already linked my donation with MAC.
Please help apprecaited
I'm not sure, I don't use the server here - but after you link your MAC (00:1A:79......), You need to enter the portal URL address on that "server" area you mentioned before, under server #1. After that, hit "connect", and you should be connected.
Other than that, you'll have to follow all the other guides and questions on this forum for other devices like the MAG254 or T1 for linking a MAC and getting it setup. Its all the same basically, minus the visual layout differences between boxes, so the procedure is pretty much identical.
Cheers
