BuzzTV xpl2000
How will this work within the interface will it be done through the BuzzTV app or a separate interface
Currently you must use the MyGica 681 USB ATSC tuner on the box and then DTV Player app which gets installed from the current Firmware update to use it
It also works with DVB-T/T2 (Using a different MyGica DVB-T/T2 Tuner) for those of you not in North America/South Korea who use ATSC signal.
Their will be an app update later that will allow you to view the channels from ATSC inside the Buzz app, it is currently being worked on along with many other features and upgrades etc.
I'm having a weird issue with a few iptv providers where when scrolling through the EPG in the Buzz TV app, it properly populates the guide for the first page or two but then subsequent pages in the EPG show "Loading Information" and shortly thereafter, if I try changing the channel, none of the streams work. I then exit the app and for a 30-40 seconds I'm unable to reconnect to the iptv server.
This issue only happens when using the EPG guide. If I scroll through the channels in the buzz tv app without using EPG, it works just fine. Given it has happened with more than one iptv provider, is there an EPG bug in the app that's causing this issue?
Mine works fine in the EPG but it might be a provider issue. For me, as I scroll page to page it populates beautifully
If you have another box handy (mag, dreamlink), you should try one of those to rule out the box or server.
It very well could be the box but I am not sure. When I had mine, there were plenty of bugs/issues that affected the Buzz but not the Dreamlink or MAG. However, that was some time ago now.
So if you can, try the same server on another box and see if it is affected as well. If it is affected - server issue. If it isn't affected - box issue.
The servers don't run special code to accommodate the Buzz, its just the same old middleware running on all the boxes. Different "features" have to be configured by the box makers to work WITH THE SERVER, and not the other way around. I feel a lot of people forget this, and it allows issues to persist for some time because not all servers show the same symptom/issue. So some users experience 0 problems and are understandably under the impression the issue is server related. Some server seem to work 100%.
I suspect lots of these issues are related to the specific servers stalker version being a newer one, which the Buzz may not fully support yet. Although this is just a guess and shouldn't be taken as fact.
I'm having the same issue here and it's real annoying. Trying to find out what the cause is, do you mind telling me what isp you're watching on? I'm on Rogers and everytime I reset my modem things tend to work again so I'm trying to figure out if it's a buzz problem or isp problem.
My ISP is Cogeco. So seems like it's not ISP related. It's annoying as hell though. I spoke with one other use who has the buzz 3000 box an apparently the latest update on that box resolves the issue but the buzz 2000 hasn't received that update?
i wish they would fix the recall button if netflix is installed
Netflix app that came with the Buzztv Box. 2000 and 3000 was the HD version...but its not working...........they said they may have to replace it with the SD version.......in the meantime you can use Netflix from the play store or Apptoid market...but you will have to use an air mouse................
