BuzzTV xpl2000
yea I uninstalled KODI 16.1 that comes preloaded with the box....after rebooting it......I saw that Kodi was reinstalled via an update..........What I did was uninstalled Kodi 16.1 again and then in google play downloaded Kodi 17.3.....rebooted the box and no more kodi 16.1............17.3 replaced it...............should work with Netflix............My stock preinstalled netflix though works just fine............
But doesn't Kodi just load the Netflix app we already have installed on the box itself? At least that's what happens with me - it loads apps installed on the box from within Kodi. So it ends up launching the Android Google Play Store version of Netflix, not the Android TV version - unless I've missed something. I'm currently running Kodi 17.3 as well. Thanks
As before and after the last update I find that when the iptv service (whichever you use) freezes or maybe not, when you press the ok button to bring up the mag-styled EPG, the stream resumes, not from where it stuck but at its live point.
I think this is a glitch within the app and not with the server iptv.
Kodi is completely separate and has nothing to do with stand alone apps.................
I've been having this very issue and it comes and goes... It was happening again today so I unplugged my box, plugged it back in, seemed to fix it for a while and then it started happening again. It's not my connection as I've tested it and the router, getting 60Mpbs on a wired connection.
Hey guys.. I'm really interested in the box but can someone comment on if you can record current or future shows (via EPG) into an USB flashstick or hard drive?
I already have Dreamlink T1+...I'd only interested in buying another box that has working RECORDING feature.
Thanks.
Thanks.
PVR for Buzztv is currently being worked on
There is a demo that is currently being tested.
