BuzzTV xpl2000
Also when I try to access the Google PlayStore it asks for my email when I enter the correct details it then asks for my last remembered password and security questions then tells me it cant verify the account is mine?
I too am using ACE but didn't run into any of those problems you suggested. I've heard of people resetting to factory default a few times to iron out some issues. What version of the BuzzTV app are you on?
Did you just put the portal url then enter your username and password under user credentials or did you enter the full m3u url with username and password included in it?
When I put the portal url ace-tv.xyz:25461/c then my user and pass in user credentials it tells me username or password is incorrect even though they are not and when I put the full m3u url in with username and pass included it just gets stuck on handshake started.
How do i contact BuzzTV support.....my epg isn't matching what is actually on and its a bit annoying as the epg was the main reason i got this box.
Could be that your problem is the IPTV Service your using and not the box..............Try using NFPS---Rocket-iptv.....or 66IPTV services .............My Buzztv with those services don't have an EPG problem
I get a great EPG on my BuzzTv.
Just a query I have with the guide and I hope someone can weigh in on it......When i pull up the EPG like the one above and certain programs begin at like 9:30 a.m. you cannot see what is on. I can only see what is coming up at the top of the hour, so the space between 9:00 - 9:30 is blank, the program coming up next is highlighted but when clicked it sets the reminder feature instead. Do you guys think it's a provider issue or the unit software, thanks.
I contacted service provider about my EPG issue and of course they denied it was their fault even though i've loaded other service providers and the EPG is fine. I guess i am just stuck right now since there doesn't seem to be any resolution in sight.
Where can you get the Service?
http://iptvprivateserver.is/
http://iptvrocket.is/
http://iptv66.com/
Those are the three official sites, the first two sell our service by year and the last sells monthly too.
Does this mean what I think it means, "[FONT=&quot]If our system detect that you are using your donation through a VPN, Proxy, Datacenter or in more than 1 device at the same time it will be automatically banned."
[/FONT]
This is what is on the IPTV Rocket main page. So they do not allow users to use their VPN's when connecting to their servers?
Which iptv service would you guys recommend? im currently using 3 that aren't mentioned in this forum which work great but aren't hosted in the US so its causing these EPG issues. The iptv services that are hosted in the US don't have those epg issues.
