BuzzTV X5 Raffle 09/10/2023
Status
Not open for further replies.
Bob Benjamin’s Aeronca Model “K”
(1/4 scale), with a wingspan of 108”
A total of 357 were built beginning in 1937
Carl Goldberg Anniversary Addition
Stock Number: GPMA0963
Cub Wingspan: 76.5 in (1943 mm)
Clipped Wing Cub: 67.5 in (1715 mm)
Cub Wing Area: 744 in² (48 dm²)
Clipped Wing Cub: 648 in² (42 dm²)
Wing Loading: 21.70 oz/ft² (66 g/dm²)
Flying Weight: 7-7.5 lbs (3.2-3.4 kg)
Fuselage Length: 48 in (1219 mm)
Requires: .40-.61 (2-stroke) or .70-.90 (4-stroke) engine, 4-channel radio, 4 standard servos, two rolls of 6-foot covering.
iu
iu
A Big Thanks to NBS, Buzz team, IPTVTalk and Farmer1...!!!
Hint
1. I am an outdoors kind of man so I do this hobby outdoors. It can be done indoors on a smaller scale.
2. I'll start of cutting it down to 3 hobby's fire arms, motor bike or Remote control.
3. Lets remove motor bike
4. I only do RC planes
5. I'm not into war birds
6. This one is a stick built kit. I bought it used so I didn't have to build it.
7. This is a scale plane. So the size is what scale it is to the original plane.
8. This plane was designed as a trainer. It is a high wing plane
9. They where built in the 1930 and 1940
10. The plane has been named but not the correct scale /wing span
Everyone's time is set to 0
Thanks to NBS and the Buzz team for there generous donation.
We will be raffling a BuzzTV X5
The raffle is open to all members and staff
Rules are simple 1 guess 12 hr
The winner will receive a BuzzTV
I just bought a new toy for one of my hobbies. New to me anyway.
What I need is Make Model and size
Hint
Good luck and have fun
I have two buddies that are really into the helicopter versions of this hobby. Pretty darn cool!!!! TO THE TOP!!!!! :o
HAN Carbon Cub 15cc ARF
Stock code A-HAN5065
Float ready, with hard points for optional 1/5-scale float set
Key Features
Laser-cut, all-wood construction that's lightweight
Shock-absorbing main landing gear and tundra-style wheels
Two-piece, plug-in wing with functional flaps
Quick-connect, streamlined wing struts
Functional LED landing lights, installed
Operational cockpit side-doors
Instrument details and seats included
Matching paint on fiberglass cowl and accessories
Pre-cut hinge locations for all control surfaces
Genuine UltraCote&reg: film finish
Tail wire detail and a leaf tail wheel
Easy installation of engine or electric power recommendations
Complete hardware package featuring fiberglass control horns
Carbon-Z Cub SS 2.1m BNF Basic with AS3X and SAFE Select
  • 2.1m wingspan with lightweight and exceptionally strong composite-reinforced, hollow-core Carbon-Z construction
  • Easy to fly with innovative, optional-use SAFE® Select flight envelope protection
  • The unmatched stability and locked-in feel of exclusive AS3X® technology
  • Spektrum™ AR637T DSMX 6-Channel AS3X & SAFE Telemetry Receiver
Man 138 post Great pick Farmer1 these long ones are really something. I am looking at the kits and thinking about getting one of therm myself now there are so many great planes out there and some really big ones too 1/4 scale is HUGE!!!!.
Thanks also to NBS, the buzz team and the staff of IPTVtalk for the raffles!!!
I had a P40 once and had a 60cc single motor my grandfather gave to me for a larger one but never got it going. Let them all go for some cycle parts years ago.
Cessna L-19A Bird Dog 98.5 wingspan
Balsa USA J-3 Piper Cub
1/4 Scale
Wing Span 108 Inches
Congrats you have come up with the correct plane Balsa USA J-3 Piper Cub
1/4 Scale. you will be receiving the BuzzTV X5
1/4 Scale
Thanks everyone for playing hope you had as much fun as I did. I was kind of running out of Hints with out it being a dead giveaway
Status
