Black screen with changing channels?! :(
Thanks Maestro,
I have two 3900 models and one is set to default player and has no black screen between channel changes.
So, I took your advice and switched the second 3900 ( The problematic one), video player to Secondary and seems to have stopped the black screen issue :) but when changed server black screen came back again although the player was still set on Secondary :( ?!
Thanks Maestro,
Then with that server use default.
I don't think it is the server as I have tried different ones to rule that out :( could the SSD that came with 3900 do that? cause my on my other 3900 for some reason the SSD stopped working and disappeared and that 3900 does not give me any black screen!
if you were playing something from ssd and gives you problem then you can say its ssd. but your issue is live tv which comes from server not through ssd. :)
again, I would say factory reset is your only solution bud. I know you dont want to loose stuff but either you loose stuff or have issue with live tv. :)
